IOC: Force Sparc 5 (frc5ce)
VxWorks 5.2
EPICS R3.12.0
I ran two tests, the first using the test database and MEDM
application suggested by Marty, and the second using the catime
program supplied with EPICS base.
Using the APS test database, I used the MEDM GUI to set the scan rate
of the master fanout record to ".1 second" which should have resulted
in the processing of 3000 records per second with associated monitors.
-> scanppl
Scan Period= 0.100000 seconds
mrkfanout
value = 0 = 0x0
Here's the final output from 'spy' after a few minutes of
running. I've removed the tasks with 0 total ticks from the listing.
Note: The scanPeriod task at PRI:52 is a 20 Hz ".05 second" scanner.
No CA events were lost. The OPI is a HP 9000 Model 715/50.
NAME ENTRY TID PRI total % (ticks) delta % (ticks)
tShell _shell ceb008 1 0% ( 1) 0% ( 0)
tSpyTask _spyTask cdead0 5 0% ( 470) 0% ( 6)
tNetTask _netTask ef8058 50 0% ( 170) 1% ( 12)
scanPeriod cff460 52 0% ( 21) 0% ( 0)
scanPeriod d01d78 53 4% ( 2402) 0% ( 3)
scanPeriod d04690 54 0% ( 9) 0% ( 0)
scanPeriod d06fa8 55 0% ( 3) 0% ( 0)
scanPeriod d098a0 56 0% ( 2) 0% ( 0)
scanPeriod d0c198 57 0% ( 1) 0% ( 0)
CA client _camsgtask ed0cc8 180 0% ( 261) 0% ( 7)
CA event _event_tas d18358 181 2% ( 1227) 5% ( 41)
CA online _rsrv_onli ed2988 183 0% ( 2) 0% ( 0)
KERNEL 0% ( 139) 0% ( 0)
INTERRUPT 0% ( 237) 0% ( 5)
IDLE 90% ( 49697) 89% ( 657)
TOTAL 96% ( 54642) 95% ( 731)
And here's the results from catime, after minor reformatting.
catime "xxx"
Soft Analog Input record, quiet system.
Test Elapsed Time Per Second
search test 0.000083 12000
float, async put test 0.000038 26000
float, async get test 0.000007 140000
float, synch get test 0.000083 12000
string, async put test 0.000057 17500
string, async get test 0.000022 45000
string, synch get test 0.000117 8500
integer, async put test 0.000035 29000
integer, async get test 0.000008 120000
integer, synch get test 0.000083 12000
free test 0.000033 30000
Aloha,
Peregrine
Peregrine M. McGehee http://www.cfht.hawaii.edu/~mcgehee
Telescope Control Systems Group Canada-France-Hawaii Telescope
(808) 885-3178 P.O. Box 1597, Kamuela, Hawaii 96743
Re: FLAME medm watson
Re: Force Sparc 5 Performance Tests Peregrine McGehee
<1996>
2025
2026
Re: GDCT under EPICS R3.13 Ric Claus
<1996>
2025
2026
