1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CaWave
To: [email protected]
Cc: [email protected]
Date: Thu, 5 Dec 1996 14:39:25 -0600
> Has anyone used the 'pvwave' EPICS extension, i.e. CaWave.so
> with PV-WAVE version 6.01?
> I have two problems.
> When I build 'CaWave.so', I get:
> Undefined			first referenced
>  symbol  			    in file
> _strerror                           (command line)
> ld: warning: Symbol referencing errors
Your problem is due to the library version on sun4.
When I built the ezcaIDL with the new default setting for EPICS R3.13.0
on sun4, I encountered the same problem.  I have to modified the
Makefile.Unix in order to build the  '.so' correctly.  The _strerror
is defined in the ansi library.
You have to make the following changes for sun4
  1) to append the '-lansi' in the  USR_LDLIBS,  and
  2) insert the library path ' -L/usr/lang/SC1.0 -L/usr/lang/SC2.0.1patch '
     in the ld line for both CaWave.so and CaIDL.so build rule.
For your reference, below is the Makefile.Unix extracted from my
private area, it should work fine for sun4 at least I tried with the
EPICS 3.13.0beta4 it worked fine.
Ben-chin
EPICS = ../../../..
include Target.include
include $(EPICS)/config/CONFIG_EXTENSIONS
DEPLIBS = $(INSTALL_LIB)/libLca.a \
           $(EPICS_EXTENSIONS_LIB)/libLca.a \
           $(EPICS_BASE_LIB)/libca.a \
           $(EPICS_BASE_LIB)/libDb.a \
           $(EPICS_BASE_LIB)/libCom.a
USR_INCLUDES = -I$(INSTALL_INCLUDE) -I$(EPICS_EXTENSIONS_INCLUDE)
USR_LDFLAGS = -L$(INSTALL_LIB)  -L$(EPICS_EXTENSIONS_LIB)
USR_LDLIBS = -lLca -lca -lCom -lDb -lCom -lansi
ifeq ($(HOST_ARCH),solaris)
USR_INCLUDES = -Kpic -I$(INSTALL_INCLUDE) -I$(EPICS_EXTENSIONS_INCLUDE)
USR_LDFLAGS = -G -L$(INSTALL_LIB)  -L$(EPICS_EXTENSIONS_LIB)
endif
UNIX_LDLIBS =
UNIX_OPT=NO
SRCS.c = ../CaWave.c
OBJS = CaWave.o
OBJS1 = CaIDL.o
PROD = CaWave.so CaIDL.so
SCRIPTS = CaWave.pro CaWidgets.pro idl_startup.pro setupidl \
	catch1d.pro catch1d.init go1d \
	catch1d_v2.pro catch1d_v2.init
DOCS = CaWave.doc catch1d_help.txt
include $(EPICS)/config/RULES.Unix
CaWave.so : $(OBJS) $(DEPLIBS)
	ld -L/usr/lang/SC1.0 -L/usr/lang/SC2.0.1patch $(LDFLAGS) -o $@ $(OBJS1) $(LDLIBS)
CaIDL.so : $(OBJS1) $(DEPLIBS)
CaWave.o : $(SRCS.c)
	$(COMPILE.c) -DPVWAVE $(SRCS.c)
CaIDL.o : $(SRCS.c)
	$(COMPILE.c) -DIDL -o $@ $(SRCS.c)
Re: CaWave Jeff Hill
Prev: CaWave Andy Foster
Next: Re: CaWave Jeff Hill
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
