Steve Hunt wrote:
> Does anyone have any portable channel access examples ?
Look in 3.13 under $(EPICS)/base/src/cas/example. Jim will
be adding an additional example to the cas directory
in the next beta release of 3.13. The CA gateway might
server as a more complex example (when it is ready for release).
> If so for which platforms has it been tried ?
So far we have compiled on the following platforms:
sunos4 {sun pro C++, GNU C++}
solaris {sun pro C++, GNU C++}
windows{NT,95} {MS vis C++} - no little endian support in gdd
HPUX {GNU C++ - native compiler has not been tried}
The "gdd" self describing data class library does not yet
support little endian architectures. Otherwise all little
endian support is in the server library.
I am close with multi-threaded/vxWorks specific portions of the
code but this may be held up for a few months while other
higher priority activities are completed (this is mostly a matter
of making the library thread safe).
We are working on the doc.
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
- Portable Channel Access Server Steve Hunt
Re: Capfast question: linking to ao .VAL field? watson
<1996>
2025
2026
More Than One Way To Stuff a .VAL Eric Bjorklund, NPSM
<1996>
2025
2026
