1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: More Than One Way To Stuff a .VAL
To: [email protected]
Date: Thu, 12 Dec 1996 9:48:27 -0700 (MST)
> I have an application where I want to connect a PP output link (of a
> genSub record) to the VAL field of a passive ao record...
> Silly me... I hadn't read the README. You connect to the SLNK field (I had
> thought that you could only connect FLNK to SLNK).
> I thought you were supposed to link to the SVAL field? (artificial name for
> the VAL field which CAPFAST treats as in IN instead of an OUT)
> Chip
> The SVAL port was added to the CEBAF symbols
> but is not provided by the symbols
> currently in use at APS, LANL and by the astronomy
> community.  The SLNK port works identically to the SVAL port,
> though using the latter would provide more meaningful documentation.
> Rozelle
I've actually done this sort of thing a lot (using a PP link from an OUTLINK
field to a VAL field).  My favorite method is to use one of the "large" or
"medium" symbols for the ao record and define one of the "user-defined" input
links (FLD0, FLD1, etc.) to be VAL.  The latest versions of e2sr/e2db do not
mind if VAL is defined as both an input and output.
					Eric Bjorklund
					Los Alamos Neutron Science Center
Prev: Re: Capfast question: linking to ao .VAL field? Rozelle Wright
Next: VME: Cannot find record type dfan Marian Zurek
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Portable Channel Access Server Jeff Hill
