1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Capfast question: linking to ao .VAL field?
To: [email protected]
Date: Thu, 12 Dec 96 09:25:51 MST
> From [email protected] Thu Dec 12 08:20:27 1996
> Return-Path: <[email protected]>
> To: [email protected] (William Lupton)
> Cc: [email protected]
> In-Reply-To: Your message of "Tue, 10 Dec 96 08:30:31 -1000."
>              <[email protected]>
> Date: Thu, 12 Dec 96 10:19:26 -0500
> X-Mts: smtp
> Content-Length: 410
> X-Lines: 11
> >> I have an application where I want to connect a PP output link (of a
> >> genSub record) to the VAL field of a passive ao record...
> >Silly me... I hadn't read the README. You connect to the SLNK field (I had
> >thought that you could only connect FLNK to SLNK).
> I thought you were supposed to link to the SVAL field? (artificial name for
> the VAL field which CAPFAST treats as in IN instead of an OUT)
> Chip
The SVAL port was added to the CEBAF symbols
but is not provided by the symbols
currently in use at APS, LANL and by the astronomy
community.  The SLNK port works identically to the SVAL port,
though using the latter would provide more meaningful documentation.
Rozelle
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs AOT-8  FAX (505) 665-5107         |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : [email protected]   |
Prev: Re: Capfast question: linking to ao .VAL field? watson
Next: More Than One Way To Stuff a .VAL Eric Bjorklund, NPSM
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Building Burt Graham Waters
