> From [email protected] Thu Dec 12 11:14:41 1996
> Return-Path: <[email protected]>
> Date: Thu, 12 Dec 1996 19:12:27 +0100 (MET)
> Reply-To: Marian Zurek <[email protected]>
> To: [email protected]
> Subject: VME: Cannot find record type dfan
> Mime-Version: 1.0
> Content-Type> : > TEXT/PLAIN> ; > charset=US-ASCII>
> Content-Length: 496
> X-Lines: 32
> Hi,
> During my development process I wanted to use Data Fanout record (1st
> time). When I tried to down-load database to the VME an error message
> appeared:
> Cannot create record E:aa_dfan
> Cannot find field DESC
> Cannot set field DESC to data fanout record
> Cannot find field SCAN
> Cannot set field SCAN to Passive
> Cannot find field PINI
> Cannot set field PINI to NO
> Thanks in advance for any suggestion.
> Regards,
> Marian Zurek
> Marian Zurek
> CERN
Are you using capfast? If so you may have an old version of the
symbol library. In the symbols edfan.sym and edfans.sym
you should have Type:dfanout.
Some of the older versions had Type:dfan.
and edb.def also matches them with
(RECORD "edfan" "edfans" "edfanm"
(Type "dfan")
For the fanout record this should be declared as
(Type "dfanout")
I checked with the version currently at APS and found that it has this
problem also.
I will discuss with Bakul how to deal with distributing symbol libraries.
Right now, I think LANL and the astronomy community have the same library,
but CEBAF may have a different one and APS is a slightly older version
of LANLs.
In the meantime, you could simply edit the symbols and edb.def and
fix them.
Rozelle
|Rozelle Wright Phone (505) 667-4804 |
|Los Alamos Natl Labs AOT-8 FAX (505) 665-5107 |
|PO Box 1663 MS-H820 Group Office (505) 667-6087|
|Los Alamos, NM 87545 email : [email protected] |
Re: VME: Cannot find record type dfan Marty Kraimer
EPICS vs. IP packs Bill Brown
<1996>
2025
2026
Re: VME: Cannot find record type dfan Marian Zurek
<1996>
2025
2026
