1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS vs. IP packs
To: [email protected] (Bill Brown)
Cc: [email protected]
Date: Thu, 12 Dec 1996 16:22:51 -0700
Hi Bill:
>There was some talk at the CERN meeting about support for IP packs under
>_EPICS_ (as opposed to under HIDEOS).  Has anyone done anything besides
>the CANbus module done at Greenwich?  Is there a list somewhere (anywhere)
>of supported IPACs?  If any?
I wrote support for this:
IPIC610/IPIC616 VME IP carrier boards
ATC40 ISA/PC carrier board
IP16-ADC
IP-DAC SU
IP-UniDig-I-E
IP-Relay
The software has never been used in 'real life', but has been running
on a PC IOC for several weeks now. The old VME software (before the PC
addition) was reportedly OK, I tried it shortly after the PC port
and hope it's unbroken ... never change a running system ;-)
The VME version was originally developed for EPICS 3.12, the PC version on
3.13.
The idea is that the same software should run on both PC and VME based
IOCs, the _very_ different handling of addresses and interrupts is
hidden in the carrier board drivers.
The drivers (not the devices) can also be compiled to use only VxWorks,
no EPICS devRegisterAddress etc.
Sometimes there is a manual available from my PC's Web server:
        http://atlanta.atdiv.lanl.gov/Gsip/main.htm
(It won't be accessible over this weekend because of a power outage.
 If I am heavily using my PC, you won't have a chance, either)
-Kay
Kay-Uwe Kasemir                 AOT-8, MS H820
[email protected]          Los Alamos National Laboratory
                                Los Alamos, NM 87545
                                Tel. (505) 665 8891
     ______| |______
    (__  __\_/______)
    (_\/_\_(X)_/_\/_)
          O'=`O                         \ o
                                          d
On January 1, 2000, some computer applications
will fail, that is if they have not already failed
between now and then...
Re: EPICS vs. IP packs Peregrine McGehee
Prev: EPICS vs. IP packs Peregrine McGehee
Next: Re: EPICS vs. IP packs Peregrine McGehee
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS vs. IP packs watson
