1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: XYCOM 566 Help
To: [email protected]
Date: Thu, 23 Jan 1997 13:42:19 EST
--- Begin Message ---
I am trying to run the XYCOM 566 ADC board in
single-ended, unipolar, 0-10V mode WITHOUT AN EXTERNAL
TRIGGER.  I want the clocks on the board to trigger
the data conversion without using an external triggering
mechanism that comes in through pin 50 of the JK1
input connector on the front of the card.  Has anyone
successfully done this?  If so, what do I need to do
to make it happen here?
I have a set of jumper settings from Bob Dalesio that
works with the single-ended scanned EPICS driver/device
support as long as I have an external trigger coming
in on pin 50 of JK1.  When I remove the external
trigger the card reads back exactly zero on all 32
channels.
I have talked to XYCOM, and they sent me some source for
programming the clocks to trigger the board internally.
Unfortunately, that did not work.
Thanks for any information!
-Alicia
Alicia S. Hofler    CEBAF at SURA/TJNAF
[email protected]        Newport News, VA
--- End Message ---
Prev: Re: Make, Scripts, Shell, Perl!? Marty Kraimer
Next: Re: Make, Scripts, Shell, Perl!? Chris Timossi
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Make, Scripts, Shell, Perl!? Richard Wolff
Next: Joerger `VDACM' 8ch/16bit waveform generator SARKAR
