Len Lawrence wrote:
> On Wed, 5 Mar 1997, Jeff Hill wrote:
> > Len Lawrence wrote:
> > > Sorry folks for introducing a VxWorks query, but after two weeks of
> > > frustration trying to make the EPICS log server work I have returned
> > > to simple file i/o (fopen, fprintf, etc) on an mv167 IOC running
> > > VxWorks 5.2.
> > What were the problems that you were having with the log server?
> > What version of EPICS are you using?
> We use the Gemini release 3 of 3.12.2.
> The basic problem was that no log file was ever created, even though no
> error messages were returned and the file descriptors always looked OK.
Have you set the following environment variables prior to running
the log server on the UNIX host:
ENV_PARAM EPICS_IOC_LOG_PORT={"EPICS_IOC_LOG_PORT","7004"};
ENV_PARAM
EPICS_IOC_LOG_FILE_LIMIT={"EPICS_IOC_LOG_FILE_LIMIT","1000000"};
ENV_PARAM
EPICS_IOC_LOG_FILE_NAME={"EPICS_IOC_LOG_FILE_NAME","/home/phebos1/epics/apple/log/i
ocLog.text"};
Have you set the following environment variables prior to calling
"iocInit()" during the vxWorks boot?
ENV_PARAM EPICS_IOC_LOG_INET={"EPICS_IOC_LOG_INET","164.54.8.167"};
> Attempts were made using logInit, logFdAdd, logFdSet - to no avail. The
> log output did however appear in the xterm window used for VxWorks i/o.
This should not be required by the application developer (all
of this occurs as a side effect of calling iocInit).
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
v 3.13 release Bill Brown
Re: VxWorks file i/o problem Chip Watson
<1997>
2025
2026
<1997>
2025
2026
