1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS variable
To: [email protected]
Cc: [email protected]
Date: Thu, 10 Apr 97 15:45:16 MDT
> From [email protected] Thu Apr 10 14:35:45 1997
> Return-Path: <[email protected]>
> Date: Thu, 10 Apr 1997 15:19:48 -0400
> Reply-To: [email protected]
> Organization: MIT Bates Linear Accelerator
> X-Mailer: Mozilla 3.0 (Win95; I)
> Mime-Version: 1.0
> To: Tech_Talk <[email protected]>
> Subject: EPICS variable
> Content-Type> : > text/plain> ; > charset=us-ascii>
> Content-Transfer-Encoding: 7bit
> Content-Length: 298
> X-Lines: 9
> Hi Folks:
> While doing a MAKE on EPICS extensions, my SunOS compiler choked on the
> following (undefined) variable :   "yylineno" . I have found it
> referenced in two files: src/edif/e2cDefParse.y & src/edif/e2cDefScan.l,
> but it is not defined, as far as I can see. Can any one enlighten me ?
> Russ
The edif tools expect to use yacc and lex instead of e_flex and antelope.
I note that the CONFIG.Unix.<arch> files all
have YACC = yacc and LEX = lex in my 3.12 config files, so edif
builds fine with those config files,
but there are not any CONFIG.Unix.<arch> files in 3.13.
The simplest thing to do would be to edit the Makefile.Unix file
in the edif directory an put the lines LEX = lex and YACC = yacc
right after the includes.  You must do a gmake clean or at least delete
all the .c files in the O.<arch> directories before remaking.
I will talk to someone about getting the change made in the
distributed copy.
Rozelle
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs AOT-8  FAX (505) 665-5107         |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : [email protected]   |
Prev: Re: EPICS - WIN32 Chris Timossi
Next: Re: EPICS - WIN32 Mark S. Engbretson
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS variable Russell J. Page, Sr.
Next: Archiving wit AR Marian Zurek
