1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gnu cross-compiler problem
To: Rolf Keitel <[email protected]>
Cc: [email protected]
Date: Tue, 15 Apr 1997 19:52:43 +0100
Rolf,
This *was* not a known bug...
I have just asked gcc to generate the assembler from the offending piece
of code, and I can understand why it causes a problem.  The statement
    if (id->asciiI != 'I' ||
        id->asciiP != 'P' ||
        id->asciiA != 'A' ||
        id->asciiC != 'C') {
        return S_IPAC_noIpacId; /* Not an IPAC */
translates into
        movel a2@,d0
        andl #16711935,d0	; 0x00ff00ff
        cmpl #4784208,d0
        jne L17
        movel a2@(4),d0
        cmpl #4259907,d0
        jeq L16
L17:
        movel #39321606,d0
        jra L18
GCC has optimised reading four bytes (spread out amongst eight bytes)
into reading two long words and masking the result for those bytes it is
interested in (this is a bl***y clever optimiser!).
The problem is that GCC has changed the access length from a word to a
long.  On our mv167 cards here, a 32-bit read in the short address space
is automatically converted by the VMEchip into two 16-bit reads, which
the IPAC was capable of handling.  I guess that your CPU/BSP allows
32-bit accesses within the short address space, but the IPAC carrier
doesn't like this.
Strictly speaking Jeff's comment about making these items volatile is
incorrect, because I know they're all in a PROM on the IPAC module and
hence cannot change at run-time.  However this does actually solve the
problem because gcc cuts out the optimisation. Change the beginning of
the ipmCheck routine by adding the volatile keyword to the definition of
id to produce the following:
int ipmCheck (
    ushort_t carrier,
    ushort_t slot
    volatile ipac_idProm_t *id;
    char dummy;Ñ
Thanks for the feedback, and appologies for the bug.
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
Re: gnu cross-compiler problem Rolf Keitel
Prev: Re: Buffer copying? Jeff Hill
Next: Re: gnu cross-compiler problem Steve Lewis
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: gnu cross-compiler problem Peregrine McGehee
Next: Re: gnu cross-compiler problem Rolf Keitel
