1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Returned mail: Host unknown (Name server: .larc.nasa.gov.: host not found)
To: [email protected] (Mail Delivery Subsystem)
Cc: [email protected]
Date: Wed, 16 Apr 97 9:40:04 EDT
> Return-Path: <[email protected]>
> Received: (from wls@localhost) by xcelsior.larc.nasa.gov
>  (8.7.6/server3.4) id JAA21635
>  for [email protected]; Wed, 16 Apr 1997 09:34:23 -0400 (EDT)
> Message-Id: <[email protected]>
> Date: Wed, 16 Apr 1997 09:34:23 -0400 (EDT)
> From: Bill Stewart <[email protected]>
> My name is Bill Stewart.  I am working at the NASA Langley Research
> Center with EPICS.  I was interested in using the dynamic assignment
> and dynamic monitoring capabilities of SNL and have run into a few
> problems.  Basically, what I attempted to do was to implement code
> similar to the example on page 22 of the "State Notation Language
> and Seq. Users Guide" with an array of floats.  It turns out that
> this example will not compile with my version of snc.  It fails on the
> following assignment:
>    long setpoint[5];
>    assign setpoint to {  };
> I was able to get it to compile by changing the curly brackets to " "
> as in the following example:
>     char str[30];
>     float pos_actual[42];
>     assign pos_actual to " ";
> Then,  I perform the following to do the dynamic assignment
> and monitoring.
>      /* do dynamic assignments on the array type parameters */
>     for (i=0; i<42;i++){
>        /* Actual jack positions from LVDT's */
>        sprintf(str,"flexcs:pos:j_pos_%d\n",i);
>        pvAssign(pos_actual[i],str);
>        pvMonitor(pos_actual[i]);
> When this segment gets loaded and run, I get an error.  Oddly enough,
> it never completes the loop.  It dies on the 25th iteration. What I get
> in debug mode is as follows:
> CA.Client.Diagnostic..............................................
>     Message: "The array or data structure specified will not fit in CA message buffer"
>     Severity: "Error" Context: "ca_add_array_event"
>     Source File: ../seq_if.c Line Number: 279
> task: 0X373aa4 taskwd
> task 1b2d18 fcs suspended
> Also, since the documentation states that the functions pvAssign and
> pvMonitor are defined to return an integer, what are the expected return
> values for successful and unsuccesful completions?  The documentation that
> I have does not state what the return values are supposed to be.  What gets
> returned (with a few mods. to the above code) is a value of "1" from
> both calls prior to the bus error. I don't believe I have a memory problem.  The version of
> EPICS is R3.12 and the version of snc is 1.9.0 for 3.12.1.  Any takers?
> Thanks for your help....
> William L. Stewart
> [email protected]
Well,  just as I sent the tech talk message about the snl problem that
I was having with dynamic assignment and monitoring, I figured out my
own problem.  As I stated in my previous message the example will not
compile.  The problem was with the following assignment:
   long setpoint[5];
This example works fine when you place " " within the curly brackets,
such as :
   long setpoint[5];
   assign setpoint to {"  "};
This seems to satisfy the compiler for the empty array.
William L. Stewart
[email protected]
Prev: [no subject] Bill Stewart
Next: Missing file Russell J. Page, Sr.
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
