1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA beacon error ?
To: Marian ZUREK <[email protected]>
Cc: [email protected]
Date: Thu, 15 May 1997 13:37:22 +0100
Marian,
do you set any of the Channel Access configuration environment variables
(probably in your resource.def file)?  I remember having problems when I
ran the course there with the restrictions which CERN make on udp/ip
broadcasts, so you probably have some specific IP addresses listed in
EPICS_CA_ADDR_LIST.  I suspect that one of those addresses is
unreachable.  Typing epicsPrtEnvParams at the vxWorks prompt will tell
you what the default values are for the Channel Access configuration
variables.  The output of that command will be a useful debugging aid
for us if you still can't work out what's wrong.
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
CA beacon error ? Marian ZUREK
Prev: Re: OffPage Input/Output examples ???? Ralph Lange
Next: waveform record & I/O interrupt scan (R13) Gabor Csuka
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA beacon error ? Marian ZUREK
Next: Re: CA beacon error ? Jeff Hill
