1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA beacon error ?
To: "Marian ZUREK" <[email protected]>, <[email protected]>
Date: Mon, 19 May 1997 10:32:16 -0600
> When I start the IOC I receive all the time an error on the IOC console:
> 0x1df36e8 (CA online): ../online_notify.c: CA beacon error was
"S_errno_ENETUNREACH"
> I suspect that there is a communication problem between IOC and the OPI
host, but no idea
> how to solve it ?
I suspect that your IOC does not have a route to one of the addresses in
the EPICS environment variable "EPICS_CA_ADDR_LIST". See the
"routeAdd()" command (function) in the vxWorks documentation. A
comparison of "routeShow()" under vxWorks with "netstat -r" under UNIX
may assist in diagnosing the problem.
Jeff
Prev: Re: waveform record & I/O interrupt scan (R13) Ned Arnold
Next: Re: waveform record & I/O interrupt scan (R13) Gabor Csuka
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA beacon error ? Andrew Johnson
Next: waveform record & I/O interrupt scan (R13) Gabor Csuka
