1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: waveform record & I/O interrupt scan (R13)
To: [email protected]
Cc: [email protected]
Date: Fri, 16 May 1997 09:21:26 -0500
> I have one question and one bug (? ) report
> 1. Question: in IOC Application Deveoper's Guide (Rel 3.13.0.beta4)
>   wrote about I/O Event Scanning, but on dbScan.c (useing SCAN_IO_EVENT)
>   faild.
>   The reason is: piosl is initialized as NULL, and never updated. Where
>   is my failure ?
Gabor,
  I'm not sure I understand how far you got. "I/O Event Scan" only works
  when the device support code supports it. The device support code must
  provide a "get_ioint_info" function, or you cannot set the record to
  "I/O Event Scanning". When the device support wants to cause the record
  to process (usually as a result of a hardware interrupt), it performs a
  scanIoRequest(pc->ioscanpvt); . devEventTestIoEvent.c in the EPICS
  distribution is a good example.
  Am I misunderstanding your question ?
  	Ned
Re: waveform record & I/O interrupt scan (R13) Gabor Csuka
Prev: Re: waveform record & I/O interrupt scan (R13) Ned Arnold
Next: Re: CA beacon error ? Jeff Hill
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: waveform record & I/O interrupt scan (R13) Gabor Csuka
