Hello All,
Heard this on the WRS mail list this morning (all unsubstantiated
rumors must be spread of course)
>> I run telnet a few times and execute the memShow command. I see that
>> the memory is slowly decreasing. I see that some is recovered from
>> time to time but not all. Is this a known problem? Is there a config-
>> uration step that I missed when setting up my system.
> There is a memory leak when you issue the logout command. We noticed
this
> because after may telnet login and logouts we ran out of memory. I
talked
> to WindRiver technical support and they acknowledged the problem. A
> workaround was to logout using the sp command. I created my own symbol
to
> call sp with logout as a parameter. The memory leak is caused because
the
> logout command exits the shell parser abnormally leaving memory
allocated.
> By spawning the logout command the shell parser can free it allocated
memory
Jeff
______________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Re: IOC error message Jeff Hill
EDD/DM: Passing multiple arguments for color rule definition ? Marian ZUREK
<1997>
2025
2026
<1997>
2025
2026
