1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC error message
To: <[email protected]>
Cc: "EPICS tech-talk mail list" <[email protected]>
Date: Mon, 2 Jun 1997 09:22:52 -0600
Russ,
> I have for the first time tried the quick start example on pg 14 of the
> EPICS Application Developer's Guide (R3.13.0.beta4). In the script
> 'st.example' is the line "iocInit" with no parameters. When booting the
> IOC, the following message appears:
> 	iocLogClient: unable to connect to 128.165.32.35 port 20000
> 	because "S_errno_ENOTCONN"
> 	iocInit failed to initialize IOC Log Client
> As I understand, this address is a LANL address. What is this doing, and
> how should I modify for Bates. The address that my network guy gave me
> to replace 128.165.32.35 is 18.77.2.57. But what is this port 20000?
Here are the parameters involved. You can set them in
base/config/CONFIG_ENV (before you build EPICS), or
in a resource.def file called by iocInit.
EPICS_IOC_LOG_PORT=7004
EPICS_IOC_LOG_INET="n.n.n.n"
EPICS_IOC_LOG_FILE_LIMIT=100000
EPICS_IOC_LOG_FILE_NAME=/a/b/c/d/iocs.log
You must also start a log server on a UNIX host that
has identical parameters in its environment.
Jeff
Prev: Re: CA and EPICS_CA_ADDR_LIST -> EPICS_CA_ADDR_FILE Jeff Hill
Next: overheard on the WRS mail list Jeff Hill
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
