1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDD/DM: Passing multiple arguments for color rule definition ?
To: [email protected]
Cc: [email protected]
Date: Mon, 02 Jun 1997 16:06:49 -0400
> Hi,
> In the EDD/DM I need to implement color rule which represents the
> highest alarm severity of two channels.
> Then I didn't found how to pass two or more arguments to the rule (is it
> possible at all ?)
> Any ideas welcome.
> Thanks in advance,
> Marian
> Marian Zurek
> CERN/ECP-CO
Hello Marian,
Yes, it is possible to pass more than one argument.  However,
you can't directly compare one alarm severity to another since
the right hand terms (the terms following the comparators)
are basically constants.
In the modify property page for the item in the "color rule
arguments" field, you can enter something like:
	A=chan1.SEVR, B=chan2.SEVR
Your color rule definition could be something like:
	$(A) 	equals 		MAJOR	and
	$(B) 	less than 	2  	use 	<A>B color>
	$(A) 	equals 		MINOR 	and
	$(B) 	equals 		NONE 	use 	<A>B color>
	$(B)	equals 		MAJOR	and
	$(A)	less than 	2	use	<B>A color>
	$(B)	equals 		MINOR	and
	$(A)	equals 		NONE	use	<B>A color>
Note that the color is selected on a "first match" basis,
Also comparisons are done based upon the type of entry, i.e.
if a string is in the third column, the value of the first
column will be compared using a string compare and a numerical
compare will be done otherwise. It's awkward since you have to
define all possible comparisons separately.
Let me know if you have more questions.
Deb
p.s.  For the next generation EPICS gui, we plan to implement a more
flexible expression evaluator for color rules, visibility,
and value conversion.
Deb Kerstiens		[email protected]
Phone			(505)667-3396
LANL AOT-8,MSH820	PO Box 1663, Los Alamos, NM. 87545
Anna Estes
Computer Sciences Corporation
NASA Langley Research Center
[email protected]
(757) 766-8266
Re: EDD/DM: Passing multiple arguments for color rule definition ? Marian ZUREK
Prev: Re: EDD/DM: Passing multiple arguments for color rule definition ? Deb Kerstiens
Next: please ignore my last email Anna M. Estes
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: High Current Motors and ACS step/pac laurence lurio
Next: Re: EDD/DM: Passing multiple arguments for color rule definition ? Marian ZUREK
