Jeff Hill wrote:
> It does appear to work that way here also. This _is_ surprising
> behavior when you are attached to the .VAl field of a bo.
> After closer inspection I discovered that the get_enum_str() entry point
> in the bo record is not using the field pointed to by paddr. Instead it
> always uses the val field. I would classify this behavior as a bug for the
> following reasons:
> 1) If another field in the bo record is of type dbr_enum and a client
> fetches it as a string then it will receive the value of the wrong field.
> Even if there isn't another field of type dbr_enum, we know that
> new records are created by copying records in base and we dont
> want to encourage this practice.
> 2) The dbr_enum values stored in the CA monitor value queue
> are not used (because pfield is pointing at the monitor queue and
> not at the database)
I will agree that the code is better written if get_enum_str checks
the field specified by the DBADDR argument. The correct way in 3.13 is
to use code like the following:
index = dbGetFieldIndex(paddr);
if(index==biRecordVAL) ...
or use a switch statement on index.
In fact this applys to ALL record support modules that have a DBADDR
argument.
HOWEVER,
The biRecord.c support code is not incorrect because there get_enum_str,
put_enum_str, get_enum_strs will ONLY get called if the field type
in question is DBF_ENUM. The only such field in the biRecord is VAL.
Many record support modules in base make this assumption.
Marty Kraimer
- Re: copying of monitored data Jeff Hill
ACS Microstepper Drives Guy_Jennings
Re: copying of monitored data Marty Kraimer
<1997>
2025
2026
<1997>
2025
2026
