1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NI-1014 help needed
To: EPICS collaboration <[email protected]>
Date: Wed, 25 Jun 1997 19:29:11 +0200
Hello,
Andrew Johnson wrote:
> Hi Josep,
> I think the stuff which Bakul has will just be a new version of the
> mv167 BSP, which is no use to you on an mv147 - I'd be surprised if they
> have actually patched vxWorks itself.
> I'm not sure if this is sufficient, but try just setting the byte at
> fffe102b to zero.  You can do this manually with:
> -> m 0xfffe102b,1
> fffe102b:  02-00
> fffe102c:  00-.
> value = 1 = 0x1
> You'll probably have to do this before iocInit though, so you might need
> to create a program to do it for you which you load and run within the
> startup script - this code should do the trick:
> void enableA24dma() {
>     unsigned char *sbar = 0xfffe102b;
>     *sbar = 0;
> Let me know if this works (or doesn't!).
> -- Andrew
Yes, IT WORKS!!! Many thanks to all the people who replied. I will,
nevertheless,try to see what John Winans did in the patch for the MVME162 and
try to
apply it for the MVME147 as a more elegant solution.
        Josep Perlas
_____________________________________________________
Dr. Josep A. Perlas - Control System and Power Technology
Lab. Sincrotro Barcelona - IFAE --------  Tel: (+34 3)581.28.38
Edifici Cn, Campus UAB     ------------   Fax: (+34 3)581.19.38
E-08193 Bellaterra (Barcelona) SPAIN ---- email: [email protected]
Re: NI-1014 help needed Bill Brown
Re: NI-1014 help needed Andrew Johnson
Prev: Tcl & Epics Steve Hunt
Next: Re: NI-1014 help needed Ned Arnold
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: NI-1014 help needed Andrew Johnson
Next: Re: NI-1014 help needed Bill Brown
