1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: change in promotion of types from database to channel access
To: "'Jeff Hill'" <[email protected]>, "'Chip Watson'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 16 Jul 1997 16:27:55 -0600
> I propose that we add dbr_ulong_t and dbr_ushort_t to the CA client API.
> Requests for these types would of course be refused when they are
> issued to old servers.
Of course the problem here is that some existing clients will not be prepared
to handle new native data types that were not in the original API. This
would not be backwards compatible. Perhaps the solution is to add a routine
to the client API that disables backwards compatible promotion when the
new types are installed. This routine would only be called only by clients that
have
been properly updated so that they are able to handle the new native types.
Backwards compatible promotion would be moved to the client lib when the new
data types are installed.
Jeff
Prev: RE: change in promotion of types from database to channel access Jeff Hill
Next: Re: change in promotion of types from database to channel access Chip Watson
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: change in promotion of types from database to channel access Chip Watson
Next: Re: change in promotion of types from database to channel access Ned Arnold
