1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: change in promotion of types from database to channel access
To: [email protected]
Date: Thu, 17 Jul 1997 08:45:01 -0400
Jeff said:
>I propose that we add dbr_ulong_t and dbr_ushort_t to the CA client API.
>Requests for these types would of course be refused when they are
>issued to old servers.
I agree this is the best long term solution, however, I wish to also patch my
3.12 system (large systems have a lot of inertia against upgrades).
>Converting unsigned32 to signed32 is of course not a good
>idea and would result in a sloppy API - which would almost certainly
influence
>clients in a way that could cause bugs.
Is anyone aware of a use of ULONG to hold a number larger than 2^31 which would
fail if the value were contained in a 32 bit int?
I would think this would only fail in the case of true positive numbers (not
masks)
greater than 2^31, and these sorts of numbers do not occur in control systems,
IMHO (the exception being the Q value of our RF cavities, and we've had plenty
of
problems dealing with those :). Control and status registers can be int's with
no ill
effects, since masking and shifting operations still would work.
The only possible ill effect I can see (as Jeff alluded to) is applications
taking
advantage (unwisely) of the fact that a double may be a ULONG and using that to
infer record type.
Chip
RE: change in promotion of types from database to channel access Jeff Hill
Prev: RE: change in promotion of types from database to channel access Jeff Hill
Next: Re: change in promotion of types from database to channel access Ned Arnold
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: change in promotion of types from database to channel access Jeff Hill
