1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: bug or feature??
To: [email protected], [email protected]
Date: Fri, 18 Jul 1997 13:17:56 -0700
Hello Marty,
Playing with R3.13.0 beta4, I found a the following behaviour (bug?,
feature?) and then found that 3.12.2 behaves in the same way:
>From the VxWorks console I used dbpf to change the SCAN field of a
record, e.g. from 1 second to 2 second . I mis-typed, and the put was
rejected with an "Illegal choice PV" value. dbpr shows the unchanged
value of the SCAN field (1 second), but scanppl shows that the record
was removed from the 1 second scan list. I assume it is not scanned any
more. Attached is the console protocol.
-> dbpr "jane1:devctl",1
ASG:                BKPT: 0x00          COSV: NO_ALARM
DESC: binary output record              DISA: 0             DISP:
0
DISS: NO_ALARM      DISV: 1             DOL:CONSTANT
0.000000000000000e+00
DTYP: Soft Channel  EVNT: 0             FLNK:CONSTANT 0     HIGH:
0
MASK: 0             NAME: jane1:devctl  OMSL: supervisory   ONAM:
disabled
OSV: NO_ALARM       OUT:CONSTANT 0.000000000000000e+00      PACT:
0
PHAS: 0             PINI: NO            PRIO: LOW           PUTF:
0
RBV: 0              RPRO: 0             RVAL: 0             SCAN: 1
second
SDIS:CONSTANT 0.000000000000000e+00     SEVR: NO_ALARM
SIML:CONSTANT 0.000000000000000e+00     SIMM: NO
SIOL:CONSTANT 0.000000000000000e+00     STAT:               TPRO:
0
TSE: 0              TSEL:CONSTANT       UDF: 0              VAL:
0
ZNAM: enabled       ZSV: NO_ALARM
value = 0 = 0x0
-> scanppl
Scan Period= 1.000000 seconds
    jane1:devctl
value = 0 = 0x0
-> dbpf "jane1:devctl.SCAN","2 secon"
Illegal choice PV: jane1:devctl.SCAN error detected in routine:
dbFastLinkConv(cvt_st_menu)
Illegal choice dbPutField error
value = 1 = 0x1
0
0
disabled
0
0
second
0
0
value = 0 = 0x0
-> scanppl
value = 0 = 0x0
: Rolf Keitel                |    [email protected]           :
: TRIUMF                     |    Tel: (604) 222-7453      :
: 4004 Wesbrook Mall         |    Fax: (604) 222-7307      :
: Vancouver, B.C., V6T 2A3   |    www.triumf.ca            :
Prev: European EPICS Meeting J.F. Gournay
Next: Re: Building EPICS on HP_UX 10.2 Ralph Lange
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: base release 3.13.0beta11 Marty Kraimer
Next: DM dropping characters in text-entry? Steve Wampler
