At SLAC, we have found the printing from EPICS to be annoyingly slow (12
minutes to print a small DM screen). We have made some measurements with
various hardware and software configurations and believe we understand the
cause of the problem. With this knowledge and a little bit of time and money we
believe we can get the printing time down to 30 seconds for a small DM display
and to 50 seconds for a larger DM display. We still consider these times to be
rather long (our old control system prints any display in 20 seconds) so we
would like to know if anyone has any advice for us before we proceed.
Based on measurements given below (and reports about what the EPICS quickprint
option does) our conclusion is that most of the time is spent by the printer's
CPU processing the bitmap sent to it in postscript format. Hence simpler
postscript files and faster printer CPUs improve the performance. In
particular, having the printer convert a color bitmap to a grayscale bitmap
causes very long printing times. File sizes were small enough that network
transfer time was calculated to be insignificant. We also see that the printer
starts processing a file almost immediately after the print job is submitted.
The other contributor to the total print time is the time taken by the host CPU
to do the screen capture and save it to a disk file in postscript format. This
time was measured and is given in the table below. It is typically less than
(but sometimes 50% of) the time taken by the printer itself.
In the data shown below, the time to print is measured from when carriage
return is hit to send a file to the printer until the page is completely out of
the printer. Typically the printing was done in two manual steps. First a
screen capture was done to disk (this time is in the column labelled "CPU").
Then the file was sent to various printers. All times are given in seconds.
Five printers were tested. LW 12/640 is an Apple Laser Writer. An older laser
writer (M5890) was also tested for some files and was similar to the Imagen.
The HP printers are HP Laser Jets.
Screen grabber and switches CPU file Imagen LW HP4SI HP5SI
size 3320 12/640
The following are for a small DM display (about 2x6 inches printed)
xwd as implemented in DM 54k 720 90
DECwindows black+white screen capture 38k 30
DECwindows grayscale screen capture 301k 60 25
xgrabsc (deflt is grayscale,compress) 54k 160 45
xgrabsc -nocompress 303k 20
xgrabsc -nocompress -bin 5 165k 40 50 20 25
xgrabsc -nocompress -bin -nolimit 5 164k 55 20
xgrabsc -bin -nolimit 27k >180
The following are for a larger DM display (about 8x10 inches printed)
xgrabsc -nocompress 30 45
xgrabsc -nocompress -cps 23 >150
xgrabsc -bin 15 >120
xgrabsc -nocompress -bin 15 740k 110 65 45 35
The following are for printing a half page ASCII file. They give an idea
of the time a printer takes for paper handling etc.
32 17 15
As you can see, sending a color postscript file with a postscript program that
the printer uses to translate it to grayscale (done by xwd and xgrabsc -cps) is
very slow. Compressing makes the file much smaller but slows down the
printer a lot. Sending binary instead of ASCII for the bitmap (-bin) with no
compression is the fastest. The HP printers are faster than the other printers
tested.
Unless someone has a clever idea, we will buy an HP5SI printer for the
control room and modify DM so that its print is like quickprint and does an
xgrabsc -nocompress -bin. We would have it provide the windowID as part of the
invocation so the operator wouldn't have to click on the window he wants to
print. To allow non-DM windows to be printed (e.g. APS stripcharts or MEDM
displays) we would provide a DM print other window option which would use the
-click switch so the operator could click on the window he wants printed. The
reason for routing all this through DM is that we have used it to select which
printer the output should go to. It certainly would be very nice though to have
a uniform printer interface for all the EPICS displays.
Any comments/clever ideas?
Tom Himel [email protected]
RE: acc? Jeff Hill
dbStatic: Escape Sequences Marty Kraimer
<1997>
2025
2026
RE: acc? Jeff Hill
RE: EPICS printing speed Jeff Hill
<1997>
2025
2026
