1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PowerPC/VME64
To: [email protected]
Date: Fri, 22 Aug 1997 14:17:28 +0100 (BST)
Peregrine,
> 2) Also, if anyone has experience with VME64 systems I'd like to know
> what the _real_ measured transfer rates are.
Under VxWorks I typically get a little over 30MByte/s average throughput
in a test in which a largish message (few Mbytes) gets ping-ponged between
2 CPUs using D64 block transfers. This includes overheads associated with
signalling between the CPUs; you could do significantly better if a slave
were just swallowing D64 blocks. Also, my application uses a device driver
to manage the transfers and this luxury degrades raw VME throughput
further. Nevertheless, if you intend to transfer rather small blocks
and/or have much else contending for the bus I wouldn't budget for _very_
much more throughput.
(These results were with MV167<-->Baja4700 transfers.)
Nick Dillon.
Royal Greenwich Observatory		Tel:   +44 1223 374740 (direct)
Madingley Road				Tel:   +44 1223 374000 (s/board)
Cambridge CB3 OEZ			Fax:   +44 1223 374700
England					E-mail: [email protected]
PowerPC/VME64 Peregrine McGehee
Prev: PowerPC/VME64 Peregrine McGehee
Next: Re: tcl/tk , tcl-dp and blt which and where? Pete Jemian
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: PowerPC/VME64 Peregrine McGehee
