1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: oms58 record support
To: [email protected]
Date: Thu, 04 Sep 1997 08:04:33 -0500
Graham Waters wrote:
> I recently build the motor record and oms58 support for R3.13.xxx.
> I can only get it to initialize properly ( I think) by explicitly
> calling motor_init() (defined in drvOms58.c) after oms58Setup() in my
> startup script.
> If I don't do this it is never called and I get the following message:
> Illegal field value PV: "my record instance name" devOms58 (init_record)
> card does not exit!
> Am I must be missing an entry table somewhere?
> Graham.
Yes you are missing a definition
driver(drvOms)
Where you place this definition depends on how you set
up your Application Source/Release Environment. If
you are following the style used by makeBaseApp the
definition would go in the
xxxApp/src/xxxInclude.dbd
Marty Kraimer
P.S. defining the desired set of record,device,driver support
     is perhaps the most frustrating part of 3.13 so have patience.
Re: oms58 record support Graham Waters
Prev: Early results of Using the Channel Access Nameserver at TJNAF David A . Bryan
Next: Re: oms58 record support Graham Waters
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: oms58 record support Benjamin Franksen
