1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: pb of acces fault when using save/restore
To: EPICS talk <[email protected]>
Date: Tue, 21 Oct 1997 17:58:32 +0200
Hi ,
My problem comes from the use save/restore routines. Before exposing my
pb, I will explain what I've done:
I'm using the Save/Restore routines with EPICS R3.12.2. Thus I 've added
the 'save_restore.c' and 'dbrestore.c' in my base, I've modified the
Makefile.Vx, and the 'initHooks.c', then I've recompiled all the base.
After I've created a .req file that contains the field to save or to
restore.
In the startup script I've add the loading of 'initHooks.o'. The first
time I've rebooted the vme, I've used the create_manual_set routine to
generate .save file. At this time, all was OK.
Then I use the 'reboot_restore()' fonction in the 'initHooks.c' to
restore values in some records after the init of the database, here is a
peace of the code (the part I've added):
case INITHOOKafterInitDatabase :
  * restore fields that init_record() would have overwritten with
  * info from the dol (desired output location).
  printf("*** restoring from 'B1MDefaults.sav' (pass 1) ***\n");
  reboot_restore("B1MDefaults.sav", 0);
     break;
Then, I've added the create_triggered_set(...) routines to save values
to the defined records. When I execute the startup script I have an
acces fault message and the vme crash. Here is the message :
Access Fault
Program Counter: 0x00029720
Status Register: 0x3000
Access Address : 0x636af44c
Special Status : 0x0485
  aa80 _vxTaskEntry   +10 : _shell (1, 0, 0, 0, 0, 0, 0, 0, 0, 0)
 32a74 _shell         +138: 32a92 ([1, 0, 0, 32898, 0])
 32c14 _shell         +2d8: _execute (1fb17d2)
 32d38 _execute       +ac : _yyparse ([0, 1, 0, 1fb17d2, 0])
 36aa4 _yyparse       +16 : _malloc (960)
 297ce _malloc        +e  : _memPartAlloc ([6c688, 960, 1fb1794, 36aa6,
960])
 29462 _memPartAlloc  +4a : _memPartAlignedAlloc ([6c688, 960, 4,
1fb1748, 297d2])
 293ca _memPartAlignedAlloc+fe : 296be (6c688, 1f8fd94, 4b4, 8, 4)
Thus I replace create_triggered_set(....) by create_monitor_set(...). So
the vme boot correctly as the startup script is executed. But later
(maybe when create_monitor_set(...) is called) I have another acces
fault and the vme crash again. Here is the message :
Access Fault
Task : "save_restore.c"
Here the problem seems to come from the save_restore task. I've no
precise idea to solve this pb because I don't know the process executed
by save_restore.c.
Is there anybody who have already met this kind of pb and/or can give me
an idea of what can be the cause.
Thanks in advance,
                                Fred
_________________________________________________
Frederic MICHAUD
CERN    : CH-1211 Geneve 23 - Switzerland
Division: ECP-CO
Phone   : Office (+41) 22 767 33 59
        : Home   (+33) 04 50 40 71 19
FAX     : Office (+41) 22 767 74 10
E-mail  : [email protected]
Prev: Re: Bug in longinRecord Marty Kraimer
Next: Re: Subarray records with a minummum profile Tim Mooney
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: edd 2.3 files to edd 1.22 files Manuel Gonzalez Berges
