1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Bug in longinRecord
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 21 Oct 1997 10:09:35 -0500
Ralph Lange wrote:
> Hi Marty,
> the longinRecord does not set UDF to FALSE when it is processed. I would
> suggest to add the marked line to process() in longinRecord.c (~ line 170):
>         status=readValue(plongin); /* read the new value */
>         /* check if device support set pact */
>         if ( !pact && plongin->pact ) return(0);
>         plongin->pact = TRUE;
>         recGblGetTimeStamp(plongin);
> *       if (status==0) plongin->udf = FALSE;
>         /* check for alarms */
>         alarm(plongin);
> I suppose the longin record is not too well used as this wasn't recognized
> for all these years...
> Regards,
> Ralph
I will make change.
Marty
Bug in longinRecord Ralph Lange
Prev: Bug in longinRecord Ralph Lange
Next: pb of acces fault when using save/restore Frederic MICHAUD
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
