1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CAC running out of sockets
To: [email protected] (EPICS Tech-Talk)
Date: Wed, 21 Jan 1998 17:00:12 +0100 (MET)
A colleague from the diagnostics group encounters the following problem on
one of his IOCs:
The IOC is the central point of some data aquisition process. I.e., the
database is connected to 16 other IOCs with one link from and one link to
each IOC.
There is a sequencer state machine supposed to be running on the IOC that
sets up one "assign" connection to an external PV (not on this IOC), three
assigns to PV on the IOC itself.
Without loading the state machine, the IOC runs without error.
When the state machine is loaded, approx. ten seconds later (obviously
while the CA clients builds the connections) the IOC starts printing error
messages of the form "CAC: ... Unable to allocate a new socket ...". The
failing CA connections correspond to CA links contained in the database,
not the state machine.
Any ideas why this happens?
Are there any limits of sockets/connections in the CA library?
Ralph
ps: the following is a log of what we tried to figure out what is
happening. The IOC hung some seconds after this log stops.
----- 8< -------------------------------
[... normal boot messages ...]
#start sequence programs
seq &iocOnOff, "IOC=MDIZ2T5G"
@(#)SEQ Version 1.9.2: Wed Feb 5 17:45:42 MET 1997
tShell 01/21/98 15:34:18: Spawning state program "iocOnOff", task name = "iocOnOff"
tShell 01/21/98 15:34:18:   Task id = 13576804 = 0xcf2a64
value = 13576804 = 0xcf2a64
Done executing startup script /opt/IOC/DiagTestSystems/bin/mv162/st.MDIZ2T5G-boot
-> iocOnOff: INIT -> OFF
-> seqCAC: ... Unable to allocate a new socket ...
CAC: for MDIZ1D2G:start.PROC on 192.168.21.163
CAC: ignored search reply- proceeding
CAC: for MDIZ1D2G:bdata on 192.168.21.163
seqShow
Program Name     Task ID    Task Name        SS Name
iocOnOff         13576804   iocOnOff         on_off
value = 0 = 0x0
-> CAC: ... Unable to allocate a new socket ...
-> ipstatShow
               total 2944
              badsum    0
            tooshort    0
            toosmall    0
             badhlen    0
              badlen    0
           fragments  678
         fragdropped    0
         fragtimeout    0
             forward    0
         cantforward    0
        redirectsent    0
value = 1 = 0x1
-> tcpstatShow
TCP:
        280 packets sent
                59 data packets (4509 bytes)
                0 data packet (0 byte) retransmitted
                78 ack-only packets (34 delayed)
                0 URG only packet
                0 window probe packet
                114 window update packets
                29 control packets
        287 packets received
                85 acks (for 4536 bytes)
                4 duplicate acks
                0 ack for unsent data
                177 packets (179264 bytes) received in-sequence
                0 completely duplicate packet (0 byte)
                0 packet with some dup. data (0 byte duped)
                0 out-of-order packet (0 byte)
                0 packet (0 byte) of data after window
                0 window probe
                0 window update packet
                1 packet received after close
                0 discarded for bad checksum
                0 discarded for bad header offset field
                0 discarded because packet too short
        18 connection requests
        21 connection accepts
        39 connections established (including accepts)
        103 connections closed (including 0 drop)
        1 embryonic connection dropped
        85 segments updated rtt (of 103 attempts)
        5 retransmit timeouts
                0 connection dropped by rexmit timeout
        0 persist timeout
        0 keepalive timeout
                0 keepalive probe sent
                0 connection dropped by keepalive
value = 36 = 0x24 = '$'
-> ipstatShow
               total 3423
              badsum    0
            tooshort    0
            toosmall    0
             badhlen    0
              badlen    0
           fragments  678
         fragdropped    0
         fragtimeout    0
             forward    0
         cantforward    0
        redirectsent    0
value = 1 = 0x1
-> inetstatShow
Active Internet connections (including servers)
PCB      Proto Recv-Q Send-Q  Local Address      Foreign Address    (state)
e1dd8c   TCP        0      0  192.168.21.178.103 192.168.21.175.506 ESTABLISHED
ffea0c   TCP        0      0  192.168.21.178.103 192.168.21.162.506 ESTABLISHED
fc080c   TCP        0      0  192.168.21.178.103 192.168.21.169.506 ESTABLISHED
ffea8c   TCP        0      0  192.168.21.178.103 192.168.21.168.506 ESTABLISHED
fc0a8c   TCP        0      0  192.168.21.178.103 192.168.21.165.506 ESTABLISHED
e1e10c   TCP        0      0  192.168.21.178.103 192.168.21.172.506 ESTABLISHED
fc090c   TCP        0      0  192.168.21.178.103 192.168.21.173.506 ESTABLISHED
ffeb0c   TCP        0      0  192.168.21.178.103 192.168.21.176.506 ESTABLISHED
fc098c   TCP        0      0  192.168.21.178.103 192.168.21.161.506 ESTABLISHED
ffec0c   TCP        0      0  192.168.21.178.103 192.168.21.174.506 ESTABLISHED
ffed0c   TCP        0      0  192.168.21.178.102 192.168.21.166.506 ESTABLISHED
d6a68c   TCP        0      0  192.168.21.178.102 192.168.21.164.506 ESTABLISHED
db768c   TCP        0      0  192.168.21.178.102 192.168.21.167.506 ESTABLISHED
fc0e0c   TCP        0      0  192.168.21.178.102 192.168.21.171.506 ESTABLISHED
e03c8c   TCP        0      0  192.168.21.178.102 192.168.21.161.506 ESTABLISHED
db7f0c   TCP        0      0  192.168.21.178.506 192.168.21.102.138 ESTABLISHED
e0408c   TCP        0      0  192.168.21.178.506 192.168.21.172.102 ESTABLISHED
e03d8c   TCP        0      0  192.168.21.178.506 192.168.21.168.102 ESTABLISHED
d99a0c   TCP        0      0  192.168.21.178.506 192.168.21.167.102 ESTABLISHED
f7bc8c   TCP        0      0  192.168.21.178.506 192.168.21.170.102 ESTABLISHED
e08f0c   TCP        0      0  192.168.21.178.506 192.168.21.176.102 ESTABLISHED
e0450c   TCP        0      0  192.168.21.178.506 192.168.21.169.102 ESTABLISHED
e1d80c   TCP        0      0  192.168.21.178.506 192.168.21.166.102 ESTABLISHED
e03f8c   TCP        0      0  192.168.21.178.506 192.168.21.174.102 ESTABLISHED
e0938c   TCP        0      0  192.168.21.178.506 192.168.21.173.102 ESTABLISHED
e0930c   TCP        0      0  192.168.21.178.506 192.168.21.163.102 ESTABLISHED
e0918c   TCP        0      0  192.168.21.178.506 192.168.21.161.102 ESTABLISHED
e0430c   TCP        0      0  192.168.21.178.506 192.168.21.165.102 ESTABLISHED
e08e8c   TCP        0      0  192.168.21.178.506 192.168.21.175.102 ESTABLISHED
e08e0c   TCP        0      0  192.168.21.178.506 192.168.21.171.102 ESTABLISHED
f7bb8c   TCP        0      0  192.168.21.178.506 192.168.21.162.102 ESTABLISHED
f7be0c   TCP        0      0  192.168.21.178.506 192.168.21.164.102 ESTABLISHED
e1da0c   TCP        0      0  0.0.0.0.5064       0.0.0.0.0          LISTEN
fc100c   TCP        0      0  192.168.21.178.102 192.168.21.170.506 ESTABLISHED
fc120c   TCP        0      0  0.0.0.0.111        0.0.0.0.0          LISTEN
fc168c   TCP        0      0  0.0.0.0.1008       0.0.0.0.0          LISTEN
fc188c   TCP        0      0  0.0.0.0.23         0.0.0.0.0          LISTEN
e0398c   UDP        0      0  192.168.21.178.103 192.168.21.178.103
e0440c   UDP        0      0  0.0.0.0.1031       0.0.0.0.0
e1d88c   UDP        0      0  0.0.0.0.1030       0.0.0.0.0
e1d90c   UDP        0      0  0.0.0.0.5064       0.0.0.0.0
fc148c   UDP        0      0  192.168.21.178.102 192.168.21.178.102
fc0d0c   UDP        0      0  0.0.0.0.1028       0.0.0.0.0
fc110c   UDP        0      0  0.0.0.0.1027       0.0.0.0.0
fc0e8c   UDP        0      0  0.0.0.0.1026       0.0.0.0.0
fc118c   UDP        0      0  0.0.0.0.5065       0.0.0.0.0
fc130c   UDP        0      0  0.0.0.0.1001       0.0.0.0.0
fc150c   UDP        0      0  0.0.0.0.111        0.0.0.0.0
value = 1 = 0x1
Re: CAC running out of sockets Marty Kraimer
Prev: Where is Pscript version of the EPICS Record Reference Man? Ernest Williams Jr.
Next: Re: CAC running out of sockets Marty Kraimer
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
