Bill wrote:
>> Is there anyone who can help with this. We aren't using these devices
>> here.
>> Rozelle
>I have no experience worth mentioning with support of GPIB on PCs, either
>under dos/windoze or EPICS. I hope that the following will be helpful
>WRT EPICS on vme.
>AFAIK, only 2 GPIB (IEEE-488) interfaces are supported by EPICS.
>The first is the (in)famous NI-1014 from National Instruments, about which
>John Winans had much to say after getting driver and device support
>working.
>The second is the Hewlett-Packard E2050A "LAN-HPIB Gateway" which has had
>support written by Ben Franksen at BESSY. I don't know if this has been
>folded into the "official" release, or even as there are plans to do so.
>(IMHO it probably should be, but it's not my call!)
In KEK, we developed a software for Tektronics ET488, which has Ethernet
and GP-IB ports. Host can controll GP-IB device connected to ET-488
over Ethernet. It is not in official release but we are happy to send
a source code. The code has been used on VxWorks on VME only.
>Hmmm - I wonder what would be required to make this code run under EPICS/
>VxWorks on an Intel platform.
< some sentencies dropped>
>Device support for the HP scope shouldn't be too big of a problem. Take
>a look at devNewSkeletonGpib.c in the EPICS source. About "all you need
>to do is" to edit command strings that the 'scope will understand into
>the param strings. While it may not seem obvious how to do that, after
>you get the first one working it's fairly straight-forward. Johns' note
>in the documentation on the web should be a good starting point.
>All of my babbling here seems pretty bland to me, but something tells
>me I'd best include a disclaimer.
We wrote a small tool nambed GDL to help a our GP-IB user. GDL translates
the follwing description,
Device(Tek2430)
/* Function proto types */
STATIC int rd_wf();
NameTable offOn = "OFF", "ON";
EfastTable userOffOn = "USER OFF", "USER ON";
EfastTable Ch1Range=
"CH1 VOLTS:2E-3", "CH1 VOLTS:5E-3", "CH1 VOLTS:1E-2"
, "CH1 VOLTS:2E-2", "CH1 VOLTS:5E-2", "CH1 VOLTS:1E-1"
, "CH1 VOLTS:2E-1", "CH1 VOLTS:5E-1", "CH1 VOLTS:1"
, "CH1 VOLTS:2", "CH1 VOLTS:5"
SrqHandler=mySrqHandler UNSolicited_SRQ;
ParamTable{
set_ch1_volt {rec=ai, command="CH1? VOL\r", conv="CH1 VOLTS:%lf",
leng=32}
get_ch1_volt {rec=ao, command="CH1 VOL:%.lf\r"}
into the device support code attached at the end of this e-mail.
We didn't put it on the net, but someone has a interest on this tool,
we will make it avaiable on the net.
Noboru Yamamot
KEK, JAPAN
=========== output from GDL tool ========================================
/* @(#)GNC Version 1.0: : Tek2430 */
* The following define statements are used to declare the names to be used
* for the dset tables.
* NOTE: The dsets are referenced by the entries in the command table.
#define DSET_AI devAiTek2430Gpib
#define DSET_AO devAoTek2430Gpib
#define DSET_BI devBiTek2430Gpib
#define DSET_BO devBoTek2430Gpib
#define DSET_SI devSiTek2430Gpib
#define DSET_SO devSoTek2430Gpib
#define DSET_LI devLiTek2430Gpib
#define DSET_LO devLoTek2430Gpib
#define DSET_MBBI devMbbiTek2430Gpib
#define DSET_MBBO devMbboTek2430Gpib
#define DSET_WF devWfTek2430Gpib
#include <vxWorks.h>
#include <taskLib.h>
#include <rngLib.h>
#include <types.h>
#include <stdioLib.h>
#include <string.h>
#include <alarm.h>
#include <cvtTable.h>
#include <dbDefs.h>
#include <dbAccess.h>
#include <devSup.h>
#include <recSup.h>
#include <drvSup.h>
#include <link.h>
#include <module_types.h>
#include <dbCommon.h>
#include <aiRecord.h>
#include <aoRecord.h>
#include <biRecord.h>
#include <boRecord.h>
#include <mbbiRecord.h>
#include <mbboRecord.h>
#include <stringinRecord.h>
#include <stringoutRecord.h>
#include <longinRecord.h>
#include <longoutRecord.h>
#include <waveformRecord.h>
#include <drvGpibInterface.h>
#include <devCommonGpib.h>
#define STATIC static
STATIC long init_dev_sup(), report();
# line 3 "../src/temp.gt"
STATIC int rd_wf();
static struct devGpibParmBlock devSupParms;
* Define all the dset's.
* Note that the dset names are provided via the #define lines at the top of
* this file.
* Other than for the debugging flag(s), these DSETs are the only items that
* will appear in the global name space within the IOC.
* The last 3 items in the DSET structure are used to point to the parm
* structure, the work functions used for each record type, and the srq
* handler for each record type.
gDset DSET_AI = {6, {report, init_dev_sup, devGpibLib_initAi, NULL,
devGpibLib_readAi, NULL, (DRVSUPFUN)&devSupParms,
(DRVSUPFUN)devGpibLib_aiGpibWork, (DRVSUPFUN)devGpibLib_aiGpibSrq}};
gDset DSET_AO = {6, {NULL, NULL, devGpibLib_initAo, NULL,
devGpibLib_writeAo, NULL, (DRVSUPFUN)&devSupParms,
(DRVSUPFUN)devGpibLib_aoGpibWork, NULL}};
gDset DSET_BI = {5, {NULL, NULL, devGpibLib_initBi, NULL,
devGpibLib_readBi, (DRVSUPFUN)&devSupParms,
(DRVSUPFUN)devGpibLib_biGpibWork, (DRVSUPFUN)devGpibLib_biGpibSrq}};
gDset DSET_BO = {5, {NULL, NULL, devGpibLib_initBo, NULL,
devGpibLib_writeBo, (DRVSUPFUN)&devSupParms,
(DRVSUPFUN)devGpibLib_boGpibWork, NULL}};
gDset DSET_SI = {5, {NULL, NULL, devGpibLib_initSi, NULL,
devGpibLib_readSi, (DRVSUPFUN)&devSupParms,
(DRVSUPFUN)devGpibLib_stringinGpibWork, (DRVSUPFUN)devGpibLib_stringinGpibSrq}};
gDset DSET_SO = {5, {NULL, NULL, devGpibLib_initSo, NULL,
devGpibLib_writeSo, (DRVSUPFUN)&devSupParms,
(DRVSUPFUN)devGpibLib_stringoutGpibWork, NULL}};
gDset DSET_LI = {5, {NULL, NULL, devGpibLib_initLi, NULL,
devGpibLib_readLi, (DRVSUPFUN)&devSupParms,
(DRVSUPFUN)devGpibLib_liGpibWork, (DRVSUPFUN)devGpibLib_liGpibSrq}};
gDset DSET_LO = {5, {NULL, NULL, devGpibLib_initLo, NULL,
devGpibLib_writeLo, (DRVSUPFUN)&devSupParms,
(DRVSUPFUN)devGpibLib_loGpibWork, NULL}};
gDset DSET_MBBI = {5, {NULL, NULL, devGpibLib_initMbbi, NULL,
devGpibLib_readMbbi, (DRVSUPFUN)&devSupParms,
(DRVSUPFUN)devGpibLib_mbbiGpibWork, (DRVSUPFUN)devGpibLib_mbbiGpibSrq}};
gDset DSET_MBBO = {5, {NULL, NULL, devGpibLib_initMbbo, NULL,
devGpibLib_writeMbbo, (DRVSUPFUN)&devSupParms,
(DRVSUPFUN)devGpibLib_mbboGpibWork, NULL}};
gDset DSET_WF = {5, {NULL, NULL, devGpibLib_initWf, NULL,
devGpibLib_readWf, (DRVSUPFUN)&devSupParms,
(DRVSUPFUN)devGpibLib_wfGpibWork, (DRVSUPFUN)devGpibLib_wfGpibSrq}};
* Debugging flags that can be accessed from the shell.
int Tek2430Debug = 0;
extern int ibSrqDebug; /* declared in the GPIB driver */
* Use the TIME_WINDOW defn to indicate how long commands should be ignored
* for a given device after it times out. The ignored commands will be
* returned as errors to device support.
* Use the DMA_TIME to define how long you wish to wait for an I/O operation
* to complete once started.
* These are to be declared in 60ths of a second.
#define TIME_WINDOW 600 /* 10 seconds */
#define DMA_TIME 60 /* 1 second */
* Strings used by the init routines to fill in the znam, onam, ...
* fields in BI and BO record types.
static char *offOnList[] = { "OFF", "ON" };
static struct devGpibNames offOn = { 2, offOnList, NULL, 1 };
* String arrays for EFAST operations. Note that the last entry must be
* NULL.
* On input operations, only as many bytes as are found in the string array
* elements are compared. If there are more bytes than that in the input
* message, they are ignored. The first matching string found (starting
* from the 0'th element) will be used as a match.
* NOTE: For the input operations, the strings are compared literally! This
* can cause problems if the instrument is returning things like \r and \n
* characters. You must take care when defining input strings so you include
* them as well.
static char *(userOffOn[])={"USER OFF","USER ON",NULL};
static char *(Ch1Range[])={"CH1 VOLTS:2E-3","CH1 VOLTS:5E-3","CH1 VOLTS:1E-2","CH1 VOLTS:2E-2","CH1 VOLTS:5E-2","CH1 VOLTS:1E-1","CH1 VOLTS:2E-1","CH1 VOLTS:5E-1","CH1 VOLTS:1","CH1 VOLTS:2","CH1 VOLTS:5",NULL};
* Array of structures that define all GPIB messages
* supported for this type of instrument.
static struct gpibCmd gpibCmds[] = {
/* CMMAND 0 set_ch1_volt */
{&DSET_AI, GPIBREAD, IB_Q_LOW, "CH1? VOL\r", "CH1 VOLTS:%lf", 0, 32, NULL, 0, 0, NULL, NULL, -1 },
/* CMMAND 1 get_ch1_volt */
{&DSET_AO, GPIBWRITE, IB_Q_LOW, NULL, "CH1 VOL:%.lf\r", 0, 32, NULL, 0, 0, NULL, NULL, -1 }
/* The following is the number of elements in the command array above. */
#define NUMPARAMS sizeof(gpibCmds)/sizeof(struct gpibCmd)
* Structure containing the user's functions and operating parameters needed
* by the gpib library functions.
* The magic SRQ parm is the parm number that, if specified on a passive
* record, will cause the record to be processed automatically when an
* unsolicited SRQ interrupt is detected from the device.
* If the parm is specified on a non-passive record, it will NOT be processed
* when an unsolicited SRQ is detected.
* In the future, the magic SRQ parm records will be processed as "I/O event
* scanned"... not passive.
static struct devGpibParmBlock devSupParms = {
&Tek2430Debug, /* debugging flag pointer */
-1, /* device does not respond to writes */
TIME_WINDOW, /* # of clock ticks to skip after a device times out */
NULL, /* hwpvt list head */
gpibCmds, /* GPIB command array */
NUMPARAMS, /* number of supported parameters */
-1, /* magic SRQ param number (-1 if none) */
"devTek2430Gpib", /* device support module type name */
DMA_TIME, /* # of clock ticks to wait for DMA completions */
mySrqHandler, /* SRQ handler function (NULL if none) */
NULL /* secondary conversion routine (NULL if none) */
* Initialization for device support
* This is called one time before any records are initialized with a parm
* value of 0. And then again AFTER all record-level init is complete
* with a param value of 1.
STATIC long
init_dev_sup(int parm)
return(devGpibLib_initDevSup(parm,&DSET_AI));
* Print a report of operating statistics for all devices supported by this
* module.
* This function will no longer be required after epics 3.3 is released
STATIC long
report(void)
return(devGpibLib_report(&DSET_AI));
* c code
Re: new record support Nick Rees
Re: about GPIB interface Benjamin Franksen
<1998>
2025
2026
Re: about GPIB interface Bill Brown
new record support Jeffrey Mcdonald
<1998>
2025
2026
