1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Running CA Server on VMS - Data Conversion Problem
To: [email protected]
Date: Thu, 29 Jan 1998 17:32:30 -0800 (PST)
Hello -
I'm running the simple example CA server on my VMS machine (ca and cas
from beta11).  I can connect and get data from it except that the
floating point data is incorrect, probably because VMS floats are
different from the rest of the world.  Perhaps this is just a build
problem.  Has anyone else solved this problem already and wish to share
their solution?  It looks like some change needed to the AIT convert
routines.
Thanks very much,
Stephanie Allison
Prev: FW: Ada vs C/C++ Jeff Hill
Next: alh group reset mask question William Lupton
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Running CA Server on VMS - Data Conversion Problem Jeff Hill
