1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Running CA Server on VMS - Data Conversion Problem
To: "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 2 Feb 1998 16:14:51 -0700
Stephanie,
> I'm running the simple example CA server on my VMS machine (ca and cas
> from beta11).  I can connect and get data from it except that the
> floating point data is incorrect, probably because VMS floats are
> different from the rest of the world.  Perhaps this is just a build
> problem.  Has anyone else solved this problem already and wish to share
> their solution?  It looks like some change needed to the AIT convert
> routines.
This is hopefully  the last major issue that needs to be resolved in the VMS port of the
ca server.
Jeff
Prev: alh group reset mask question William Lupton
Next: Re: Running CA Server on VMS - Data Conversion Problem saa
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Running CA Server on VMS - Data Conversion Problem saa
