1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: processing on put to .VAL field
To: William Lupton <[email protected]>, [email protected]
Date: Wed, 04 Feb 1998 07:30:35 -0600
William Lupton wrote:
> Marty,
>   I raised this the other week and I thought you might have an opinion.
> I had misunderstood what was happening at first but it still seems
> strange that processing a PP (DB) output link to a Passive calc record
> results in:
> a) posting a monitor with the pushed value
> b) processing the record and (typically) posting a monitor with a
>    _different_ value
> So I was wondering what the rationale behind having the VAL field's
> PP attribute FALSE on some record types is. It would seem more logical
> always to set it TRUE (but that might break some existing code I suppose).
>   Thanks,
>   William
I looked and the following record types do not have PP(TRUE) set for the
VAL field.
calc, calcout, event, fanout, histogram, pal, pulseCounter, pulseDelay,
scan, and wait.
It seem reasonable to set PP(TRUE) on the VAL field of all record types.
Can anyone see a problem if we do this?
Marty Kraimer
Prev: Re: EPICS r3.13 field VERS and RTYP Chip WATSON
Next: burt 'features' Matthias Clausen DESY -MKS-2/KRYK-
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS r3.13 field VERS and RTYP Steve Lewis
Next: Re: processing on put to .VAL field Ned Arnold
