1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: burt 'features'
From: Matthias Clausen DESY -MKS-2/KRYK- <[email protected]>
To: [email protected]
Cc: [email protected], [email protected]
Date: Wed, 4 Feb 1998 14:52:49 +0100 (MET)
I found the following features in burtrb:
usage: burtrb -f req1 {req2 ...} {-l logfile} {-o outfile} {-d} {-v}
                {-c ... comments ...} {-k keyword1 ... keywordn}
                {-r retry count} {-sdds or -nosdds} {-Dname{=def}}
                {-Ipathname}
where
        -f req1 {req2 ...} - Request filenames. This is the only switch
                that is not optional.  You must specify at least one request
                file.
Using burtrb from within a directory scecifying just file.req always
crashes burt.
Since I did not believe that we did have some crab in the distribution I used
the burtgooey and had no problems ;-)
Looking at the command beeing executed I saw that the absolute file (including
the directory path) was used. Typing this in:
burtrb -f /dir/dir1/dir2/file.req works!
Well - since not all of us use the gooey ... there's room for improvements.
Matthias
Prev: Re: processing on put to .VAL field Marty Kraimer
Next: Re: processing on put to .VAL field Ned Arnold
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: processing on put to .VAL field William Lupton
Next: error in iocLogServer.c Pete Jemian
