1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: GPIB+VxWorks3.5.1 problem
To: [email protected]
Cc: [email protected]
Date: Wed, 25 Feb 1998 07:21:55 -0800
You don't say what your vxWorks host processor is, so I'll take a stab in
the dark here.
The way WRS handles the issue of making processor memory visable from the
vme bus is a bit strange, at least to our way of thinking.  You may recall
that John W. patched the kernel to provide a fix for the memory mapping,
which is necessary because the NI-1014 board does DMA to the cpu memory.
If the memory<->vme bus mapping is not correct you will get errors similar
to what you are describing.  I don't know if there are other examples of
device/driver support that also use DMA.
AFAIK this may only apply to mv162 processors, but it seems reasonable that
there are others that may suffer from the same problem.  I know at one point
I had to kludge other Motorola cards because of similar problems.
You might compare Johns' modified kernel against the old and new "stock
kernels; perhaps the results may point to a solution.
Disclaimer:  Any opinions are my own and have	    |  -bill
    nothing to do with the official policy or the   |   [email protected]
    management of L.B.N.L, who probably couldn't    |   Berkeley, CA
    care less about employees who play with trains. |   aka [email protected]
Prev: GPIB+VxWorks3.5.1 problem Josep A. Perlas
Next: can't boot VxWorks on MVME177 Paul Sichta
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
