1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA_LINK in DOL field of AO record.
To: [email protected]
Date: Wed, 04 Mar 1998 09:24:30 -0600
Noboru Yamamoto wrote:
> Dear Colleague,
>  One of my colleague try to get output value of AO record from the record
> on another IOC. So he put channel name in DOL field. After initializing
> IOC, dbpr command shows that DOL has CA_LINK.
> However value which this AO record got is jut garbage.
> After looking at the codes, aoRecord.c and aiRecord.c and devAiSoft.c,
> I modified one line of code in aoRecord.c. With this modification,
> AO record get correct number from CA_LINK.
> I'm not quite sure if it has another side effect. Honestly speaking,
> I don't understand why original code get the garbage and why the modified
> version does get the correct number.
> Anyway, here is a original code in aoRecord.c.
> ===== extracted from aoRecord.c ======================================
> static long process(pao)
>         struct aoRecord     *pao;
>         struct aodset   *pdset = (struct aodset *)(pao->dset);
>         long             status=0;
>         unsigned char    pact=pao->pact;
>         double          value;
>         if ((pdset==NULL) || (pdset->write_ao==NULL)) {
>                 pao->pact=TRUE;
>                 recGblRecordError(S_dev_missingSup,(void *)pao,"write_ao");
>                 return(S_dev_missingSup);
>         /* fetch value and convert*/
>         if (pao->pact == FALSE) {
>                 if ((pao->dol.type != CONSTANT) &&
>                     (pao->omsl == CLOSED_LOOP)) {
>                    fetch_value(pao, &value);
>                 else {
>                    value = pao->val;
>                 convert(pao, &value);
I looked a little closer and I think the problem is that fetch_value
does not change value if dbGetLink reports an error. Since value is not
initialized it is just garbage in this case. This will happen whenever
the CA link has a problem.
Noboru,
Is this what happened?
If this is true then the change should be:
                   status = fetch_value(pao, &value);
                else {
                   value = pao->val;
                if(!status) convert(pao, value);
And fetch_value modified to return a status value.
I will change it for the next release of epics.
Marty Kraimer
CA_LINK in DOL field of AO record. Noboru Yamamoto
Prev: CA_LINK in DOL field of AO record. Noboru Yamamoto
Next: 16-bit A/D and D/A conversions Garrett D. Rinehart
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
