Dear Colleague,
One of my colleague try to get output value of AO record from the record
on another IOC. So he put channel name in DOL field. After initializing
IOC, dbpr command shows that DOL has CA_LINK.
However value which this AO record got is jut garbage.
After looking at the codes, aoRecord.c and aiRecord.c and devAiSoft.c,
I modified one line of code in aoRecord.c. With this modification,
AO record get correct number from CA_LINK.
I'm not quite sure if it has another side effect. Honestly speaking,
I don't understand why original code get the garbage and why the modified
version does get the correct number.
Anyway, here is a original code in aoRecord.c.
===== extracted from aoRecord.c ======================================
static long process(pao)
struct aoRecord *pao;
struct aodset *pdset = (struct aodset *)(pao->dset);
long status=0;
unsigned char pact=pao->pact;
double value;
if ((pdset==NULL) || (pdset->write_ao==NULL)) {
pao->pact=TRUE;
recGblRecordError(S_dev_missingSup,(void *)pao,"write_ao");
return(S_dev_missingSup);
/* fetch value and convert*/
if (pao->pact == FALSE) {
if ((pao->dol.type != CONSTANT) &&
(pao->omsl == CLOSED_LOOP)) {
fetch_value(pao, &value);
else {
value = pao->val;
convert(pao, &value);
I modified the call of fetch_value() as follows. &(pao->val) is passed
as second argument instead of &value. A value of "value" variable
is updated by the return value of fetch_value().
===== extracted from modified aoRecord.c ======================================
long status=0;
double value;
pao->pact=TRUE;
fetch_value(pao, &(pao->val));
value=pao->val;
else {
value = pao->val;
Thanks for reading my report.
Noboru Yamamoto
KEKB control group
KEK, JAPAN
Noboru Yamamoto
KEKB Accelerator Control Group
KEK, JAPAN
Fax:+81-298-64-0321
Tel:+81-298-64-5309
e-mail:[email protected]
- Re: CA_LINK in DOL field of AO record. Marty Kraimer
Re: first serial devSupp Li Jingyi
<1998>
2025
2026
<1998>
2025
2026
