Subject: |
Proposal for change in bo record |
Benjamin Franksen <[email protected]> |
To: |
b-tech-talk |
Date: |
Tue, 10 Mar 1998 16:17:10 +0100 |
Hello Marty,
Ralph told me that you accept proposals for changes in record types and
supports until the 20th of March. Here is one:
The bo record has a field HIGH which - if set to a value other than zero
- re-processes the record whenever it has been processed with VAL field
set to one. This is unfortunate in case the bo record does the usual
conversion (zero to zero, non-zero to MASK). What one expects in this
case is - I'd say - that the re-processing with zero happens whenever
the record is processed with a value other than zero.
Concrete: replace the two occurrences of
if (pbo->val==1 && wait_time>0) {
with
if (pbo->val && wait_time>0) {
Another way to achieve the same result - a more radical way - would be
to convert VAL to zero or one _always_ on entry to process() resp. when
VAL is retrieved, independent from any device specific conversion.
Perhaps the most radical solution would be to introduce some DBF_BOOLEAN
data type which is then automatically converted, but this would probably
go a bit too far...
Ben
The Notorious Neb Nesknarf
BESSY II
Berliner Elektronenspeicherring- phone: +49 30 6392-4865
Gesellschaft fuer Synchrotronstrahlung fax: +49 30 6392-4859
Rudower Chaussee 5 email: [email protected]
D-12489 Berlin web: http://www.bessy.de/~franksen
HOME: Benjamin Franksen, Fichtestr. 19a, D-10967 Berlin, +49(30)6913756
Collaboration meet APril 29,30, May1 Bob Dalesio
Proposal for boosted Symb device support Benjamin Franksen
<1998>
2025
2026
<1998>
2025
2026
