Benjamin Franksen wrote:
> Hello Marty (and all the others),
> another proposal (suggested by Goetz Pfeiffer): Currently there is a
> 'Symb' device support for ai, ao, longin, longout, stringin and
> stringout records. Their purpose is to associate the records VALue with
> some globally visible VxWorks variable through the use of VxWorks'
> symbol table. But the implementation is rather crude: Neither is there
> any protection against race conditions while copying the value, nor is
> there the possibility to supply the name of the symbol independently
> from the record's name resp. naming convention.
In the next release of base the version of Symb* is that supplied by
William Lupton. It is a major change to the old support while keeping
compatibity. William interacted with Steve Lewis while designing and
implementing the changes.
> Both can be mended easily:
> (1) To protect the data transport, simply add some
> intLock()
> intUnlock()
> pairs around the critical section, which is for example in devAiSymb the
> single line
> pai->val = *(double *)(pai->dpvt);
> (2) To enable record name independent symbol names, check the hw link if
> it equals INST_IO. If yes, get the symbol name from the link, otherwise
> (ie the link is CONSTANT) use the previous algorithm as a fallback
> method.
> I'd volunteer to code the proposed changes, if there is interest and
> there are no objections to them.
I will send you the latest version.
Marty
- Proposal for boosted Symb device support Benjamin Franksen
Re: Proposal for boosted Symb device support Andrew Johnson
Re: Greenspring rs422 support Joseph P. Sullivan
<1998>
2025
2026
RE: Proposal for boosted Symb device support Jeff Hill
<1998>
2025
2026
