1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Proposal for boosted Symb device support
To: "'Andrew Johnson'" <[email protected]>, Benjamin Franksen <[email protected]>
Cc: Marty Kraimer <[email protected]>, EPICS Techtalk <[email protected]>
Date: Wed, 11 Mar 1998 09:37:35 -0700
On Tuesday, March 10, 1998 8:46 AM, Andrew Johnson [SMTP:[email protected]] wrote:
> Benjamin Franksen wrote:
> > another proposal (suggested by Goetz Pfeiffer): Currently there is a
> > 'Symb' device support for ai, ao, longin, longout, stringin and
> > stringout records.
> > (1) To protect the data transport, simply add some
> >         intLock()
> >         intUnlock()
> This is unnecessary as long as the value is read in a single cycle - for
> longs certainly, and possibly for doubles too (I'd need to check the
> compiler output to be sure of this one).  It may be worth doing this for
> strings and waveforms though (added by me, see below).
I agree that this is normally only required for multi-element data such
as waveforms and strings.
It is almost always preferable to use a semTake()/semGive() of a vxWorks
mutual exclusion semaphore instead of the intLock()/intUnlock() in task
level code. I prefer not to cause time critical ISRs to wait while we are
copying an array in task level code. Frequently, it is also preferable to
specify the task delete safe and priority inheritance options when creating
a mutex semaphore in a code that will be used at many different sites.
Jeff
Re: Proposal for boosted Symb device support Benjamin Franksen
Prev: Re: SNC crashes Thomas Birke
Next: Re: synchronizing client requests & completions Peregrine M. McGehee
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Proposal for boosted Symb device support Marty Kraimer
Next: Re: Proposal for boosted Symb device support Benjamin Franksen
