Dave,
On Tuesday, March 17, 1998 6:03 PM, Dave Barker [SMTP:[email protected]] wrote:
> I'm getting the following problems when running MEDM on my
> solaris 2.6 machines:
> CA.Client.Diagnostic..............................................
> Message: "No internet interface with broadcast available"
> Severity: "Warning" Context: "caAdd : ca_build_and_connect failed
> Source File: ../medmCA.c Line Number: 680
> but when I ifconfig -a, I get:
> lo0: flags=849<UP,LOOPBACK,RUNNING,MULTICAST> mtu 8232
> inet 127.0.0.1 netmask ff000000
> hme0: flags=863<UP,BROADCAST,NOTRAILERS,RUNNING,MULTICAST> mtu 1500
> inet 206.61.208.109 netmask ffffff00 broadcast 206.61.208.255
Quick workaround:
Set EPICS_CA_AUTO_ADDR_LIST to NO and specify an explicit broadcast
address in EPICS_CA_ADDR_LIST (see the CA reference manual).
Long term:
The code involved is in base/src/ca/if_depn.c
in routine caDiscoverInterfaces(). One possibility is that the code has to
be recompiled on Solaris 2.6 in order for the interface flags or ioctl codes
to be defined correctly. You might look in the release notes for Solaris 2.6.
You could also build EPICS base with debug (ie HOST_OPT = NO) and then
step through this routine in the debugger to get a closer look at the
situation.
I just spoke with Rozelle here, and it turns out that we recently installed a
Solaris 2.6 machine here. Rozelle said that she will try to reproduce
the problem here.
Jeff
> the broadcast address is set correctly for a Class C network. I have
> seen this problem
> on all types of Solaris 2.6 machines (E2 and Ultra30).
> Can anyone help with this?
> thanks,
> Dave Barker.
> Dave Barker | Tel Office: 509 373 6203 (msg service)
> LIGO Hanford Observatory | Lab 0: 509 373 3580
> P.O. Box 1970; MS S9-02 | Lab 1: 509 372 3976
> Richland | Fax 509 372 2178
> WA 99352 | e-mail [email protected]
> United States of America | S/W Engineer, UNIX Sys Admin.
CA broadcast problems on Solaris 2.6? Dave Barker
RE: CA broadcast problems on Solaris 2.6? Rozelle Wright
<1998>
2025
2026
<1998>
2025
2026
