edd and cau which were built on Solaris 2.5.1 with Epics libraries built on
2.5.1 work fine from the Solaris 2.6 machine. I will try rebuilding the
Channel access libraries on that machine and see what happens.
Rozelle
> From [email protected] Wed Mar 18 10:54 MST 1998
> To: "'Dave Barker'" <[email protected]>,
> "[email protected]"
> <[email protected]>
> Subject: RE: CA broadcast problems on Solaris 2.6?
> Date: Wed, 18 Mar 1998 10:35:11 -0700
> Organization: LANL
> X-Mailer: Microsoft Internet E-mail/MAPI - 8.0.0.4211
> Mime-Version: 1.0
> Content-Transfer-Encoding: 7bit
> X-Lines: 66
> Dave,
> On Tuesday, March 17, 1998 6:03 PM, Dave Barker [SMTP:[email protected]] wrote:
> > I'm getting the following problems when running MEDM on my
> > solaris 2.6 machines:
> > CA.Client.Diagnostic..............................................
> > Message: "No internet interface with broadcast available"
> > Severity: "Warning" Context: "caAdd : ca_build_and_connect failed
> > Source File: ../medmCA.c Line Number: 680
> > but when I ifconfig -a, I get:
> > lo0: flags=849<UP,LOOPBACK,RUNNING,MULTICAST> mtu 8232
> > inet 127.0.0.1 netmask ff000000
> > hme0: flags=863<UP,BROADCAST,NOTRAILERS,RUNNING,MULTICAST> mtu 1500
> > inet 206.61.208.109 netmask ffffff00 broadcast 206.61.208.255
> Quick workaround:
> Set EPICS_CA_AUTO_ADDR_LIST to NO and specify an explicit broadcast
> address in EPICS_CA_ADDR_LIST (see the CA reference manual).
> Long term:
> The code involved is in base/src/ca/if_depn.c
> in routine caDiscoverInterfaces(). One possibility is that the code has to
> be recompiled on Solaris 2.6 in order for the interface flags or ioctl codes
> to be defined correctly. You might look in the release notes for Solaris 2.6.
> You could also build EPICS base with debug (ie HOST_OPT = NO) and then
> step through this routine in the debugger to get a closer look at the
> situation.
> I just spoke with Rozelle here, and it turns out that we recently installed a
> Solaris 2.6 machine here. Rozelle said that she will try to reproduce
> the problem here.
> Jeff
> > the broadcast address is set correctly for a Class C network. I have
> > seen this problem
> > on all types of Solaris 2.6 machines (E2 and Ultra30).
> > Can anyone help with this?
> > thanks,
> > Dave Barker.
> > Dave Barker | Tel Office: 509 373 6203 (msg service)
> > LIGO Hanford Observatory | Lab 0: 509 373 3580
> > P.O. Box 1970; MS S9-02 | Lab 1: 509 372 3976
> > Richland | Fax 509 372 2178
> > WA 99352 | e-mail [email protected]
> > United States of America | S/W Engineer, UNIX Sys Admin.
RE: CA broadcast problems on Solaris 2.6? Jeff Hill
Re: CA broadcast problems on Solaris 2.6 Rozelle Wright
<1998>
2025
2026
<1998>
2025
2026
