The forth paragraph in Chapter 30 (Sequence Record) Section 5 (Selection
Algorithm Parameters) of the Record Reference Manual R3.13 is wrong:
Instead of
When Mask is chosen, each time the record is processed, the record uses the
integer value from the SELN field as the number of links to process,
starting with the first link. For instance, if Mask is 3, then the record
will retrieve the values from DO1-DO3 and write them to the locations in
LNK1-LNK3.
it should read
integer value from the SELN field as a mask to determine the links to
process. For instance, if SELN is 1, then the value from DO1 will be
written to the location in LNK1. If SELN is 3, the record will retrieve the
values from DO1 and DO2 and write them to the locations in LNK1 resp.
LNK2. If SELN is 63, DO1...DO6 will be written to LNK1...LNK6.
Ralph
- Re: BUG in Record Reference Manual R3.13 Ralph Lange
April Collaboration Meeting Bob Dalesio
3.13 Install question Andrew Johnson
<1998>
2025
2026
<1998>
2025
2026
