Can someone working on 3.13 respond to this guy please, I can't help him
just at the moment.
-- Andrew
___
.' `. Andrew Johnson, Head of Electronics
/ Royal ) Royal Greenwich Observatory
\ Greenwich Madingley Road, Cambridge, CB3 0EZ
| Observatory Tel: +44 1223 374823 Fax: 374700
+---------- WWW: http://www.ast.cam.ac.uk/~anj
------- Forwarded message follows -------
-----------------------------(+DS(6N(0Dy)-----------------------------
Return-Path: <[email protected]>
Received: from relay-5.mail.demon.net ([194.217.242.5])
by rgotsg-mf.demon.co.uk with SMTP
id <[email protected]> for <[email protected]>
; Fri, 20 Mar 1998 08:40:07 +0100
Received: from punt-2.mail.demon.net by mailstore for [email protected]
id 890367984:05:01736:0; Fri, 20 Mar 98 04:26:24 GMT
Received: from lilac.csi.cam.ac.uk ([131.111.8.44]) by punt-2.mail.demon.net
id aa0501709; 20 Mar 98 4:26 GMT
Received: from cass41.ast.cam.ac.uk [131.111.69.186]
by lilac.csi.cam.ac.uk with esmtp (Exim 1.82 #1)
id 0yFtNt-0004ht-00; Fri, 20 Mar 1998 04:26:21 +0000
Received: from Garkbit.ast.cam.ac.uk (garkbit.ast.cam.ac.uk [131.111.69.222])
by cass41.ast.cam.ac.uk (8.8.8+Sun/8.8.8) with SMTP id EAA20467
for <[email protected]>; Fri, 20 Mar 1998 04:26:20 GMT
Received: from cass41.ast.cam.ac.uk by Garkbit.ast.cam.ac.uk (SMI-8.6/SMI-SVR4-anj-4)
Received: from lilac.csi.cam.ac.uk (lilac.csi.cam.ac.uk [131.111.8.44])
by cass41.ast.cam.ac.uk (8.8.8+Sun/8.8.8) with SMTP id EAA20464
for <[email protected]>; Fri, 20 Mar 1998 04:26:18 GMT
Received: from codia.postech.ac.kr [141.223.100.111]
id 0yFtNg-0004hR-00; Fri, 20 Mar 1998 04:26:10 +0000
Received: (from root@localhost)
by codia.postech.ac.kr (8.8.8H1/8.8.8) id NAA01533
for [email protected]; Fri, 20 Mar 1998 13:23:33 +0900 (KST)
Date: Fri, 20 Mar 1998 13:23:33 +0900 (KST)
Message-Id: <[email protected]>
Content-Type: text
Apparently-To: <[email protected]>
Bcc:
Dear Sir
I am a graduate student of POSTECH in Korea.
( POSTECH and POSCO built Pohang Accelerator Laboratory [PAL] )
I must install EPICS in my machine to develope the longitudinal feedback system.
But I can't install EPICS in my machine. Some errors happened.
My machine is SUN Enterprise Server 450.
OS is Solaris2.6
VxWorks is the Tornado-1.0.1 which is located at /usr/local/tornado-1.0.1
EPICS is the EPICS-3.13.0.b11 which is located at /usr/local/epics
GCC for HOST (Solaris) is gcc-2.7.2.3 which is located /usr/local/gcc-2.7.2.3
GCC for sun3 is gcc-2.7.2.3 wihich is localted at /usr/local/hideos/gnu/gcc-2.7.2.3
GCC BIN for HOST is located at /usr/local/bin
GCC BIN for sun3 is located at /usr/local/hideos/gnu/bin
GCC BIN for Vx-Works (i.e cc68k, as68k etc...) is located
at /usr/local/tornado-1.0.1/host/sun4-solaris2/bin
Sun Compiler is located /opt/SUNWspro/
I must compile EPICS for the target boards which are the mv162 and mv166.
first, I Compiled EPICS for HOST :
After editing /usr/local/epics/base/config/CONFIG, CONFIG.SITE, CONFIG.solaris
CONFIG.mv162, CONFIG_SITE.solaris, CONFIG.Vx.68k, CONFIG_COMMON
,CONFIG_BASE.
Question[1] : Are they the right files to edit ?
after editing such files;
make clean
make depends.solaris
make solaris
make install.solaris
in order to install EPICS for HOST
Question[2] : Are they the right processes ?
and Installation for HOST had no any error.
So I tried to install mv162.
make depends.mv162
make mv162
But in making mv162, Some errors happened:
Question[3] do you know why those errors happened ?
------ Error Messages in making mv162 ----------------------------
make[2]: Entering directory `/usr/local/epics-3.13.0.b11/base/src/libCom'
make -C O.mv162 -f ../Makefile.Vx T_A=mv162
make[3]: Entering directory `/usr/local/epics-3.13.0.b11/base/src/libCom/O.mv162'
rm -f calcPerform.o
/usr/local/tornado-1.0.1/host/sun4-solaris2/bin/cc68k -B/usr/local/tornado-1.0.1/host/sun4-solaris2/lib/gcc-lib/ -nostdinc -DCPU=MC68040 -m68040 -DCPU_FAMILY=MC680X0 -O -Wall -pedantic -ansi -I. -I.. -I../../../src/include/os/vxWorks -I../../../include -I../../../include -I../../../include/os/vxWorks -I/usr/local/tornado-1.0.1/target/h -DvxWorks -DV5_vxWorks -c ../calcPerform.c
In file included from ../calcPerform.c:109:
/usr/local/tornado-1.0.1/target/h/string.h:39: warning: conflicting types for built-in function `memcmp'
/usr/local/tornado-1.0.1/target/h/string.h:40: warning: conflicting types for built-in function `memcpy'
as: unrecognized option `-m68040'
make[3]: *** [calcPerform.o] Error 1
make[3]: Leaving directory `/usr/local/epics-3.13.0.b11/base/src/libCom/O.mv162'
make[2]: *** [mv162] Error 2
make[2]: Leaving directory `/usr/local/epics-3.13.0.b11/base/src/libCom'
make[1]: *** [libCom.mv162] Error 2
make[1]: Leaving directory `/usr/local/epics-3.13.0.b11/base/src'
make: *** [src.mv162] Error 2
codia[146]#
So I can't install EPICS anymore.
If do you know the reason making errors. Please help me.
My CONFIG files are:
1) /base/config/CONFIG
# $Id: CONFIG,v 1.11 1997/06/25 00:48:06 jhill Exp $
# The developer may edit this file.
# assume T_A is the host arch if not specified
ifndef T_A
T_A = $(HOST_ARCH)
endif
# EPICS base definitions
include $(EPICS_BASE)/config/CONFIG_COMMON
# Site-specific build options
include $(EPICS_BASE)/config/CONFIG_SITE
# Architecture specific definitions
include $(EPICS_BASE)/config/CONFIG.$(T_A)
-include $(EPICS_BASE)/config/CONFIG_SITE.$(T_A)
# User specific definitions
-include $(HOME)/EPICS_CONFIG
-include $(HOME)/EPICS_CONFIG.$(HOST_ARCH)
# All EPICS options other than BUILD_TYPE
# may be overridden here.
# EXAMPLES
# Build client objects statically ? must be either YES or NO
#STATIC_BUILD=NO
# Unix Optimization, must be either YES or NO
#UNIX_OPT=YES
# VxWorks Optimization, must be either YES or NO
#VX_OPT=YES
# Generate Verbose Compiler Warnings for Unix, must be either YES or NO
#UNIX_WARN=YES
# Generate Verbose Compiler Warnings for VxWorks, must be either YES or NO
#VX_WARN=YES
#etc.
2) /base/config/CONFIG.Vx.68k
# $Id: CONFIG.Vx.68k,v 1.17 1997/05/05 17:56:58 jba Exp $
# This file is maintained by the EPICS community.
AR = $(VX_GNU_BIN)/ar68k
RANLIB = $(VX_GNU_BIN)/ranlib68k
YACC = $(EYACC)
LEX = $(ELEX)
CC = $(VX_GNU_BIN)/cc68k -B$(VX_GNU_LIB)/gcc-lib/ -nostdinc
CPP = $(VX_GNU_BIN)/cpp68k -nostdinc
#CPP = $(CC) -E
GCC = $(CC)
LD = $(VX_GNU_BIN)/ld68k -r
EPICS_LDLIBS =
MV=mv
RM=rm -f
MKDIR = mkdir
RMDIR=rm -rf
WHAT = what
# Only G++ currently supported
CPLUSPLUS = G++
CXXCMPLR = NORMAL
VX_OPT = YES
BOARD = $(subst mv,MV,$(T_A))
CPU = 68000
OS = VXWORKS
CCC = $(VX_GNU_BIN)/cc68k -B$(VX_GNU_LIB)/gcc-lib/ -nostdinc
AR_CCC = $(VX_GNU_BIN)/ar68k
CPP_CCC = $(VX_GNU_BIN)/cpp68k -nostdinc
RANLIB_CCC = $(VX_GNU_BIN)/ranlib68k
LD_CCC = $(VX_GNU_BIN)/ld68k
CCC_CCFLAGS =
CCC_ARCH_DEP_CCFLAGS =
CCC_ARCH_DEP_LDFLAGS =
G++ = $(GNU_BIN)/sun3-g++ -B$(GNU_LIB)/gcc-lib/ -nostdinc -DEXPL_TEMPL
AR_G++ = $(GNU_BIN)/sun3-ar
CPP_G++ = $(GNU_BIN)/sun3-c++
RANLIB_G++ = $(GNU_BIN)/sun3-ranlib
LD_G++ = $(GNU_BIN)/sun3-ld
G++_ARCH_DEP_CCFLAGS = --no-builtin -Wa,"-m68040" -DOS_EQ_$(OS) \
-DBOARD_EQ_$(BOARD) -DCPU_EQ_$(CPU) -DBOARD=$(BOARD)
G++_ARCH_DEP_LDFLAGS = -Ur -N -T$(EPICS_BASE_BIN)/vxldscript.MRI
CCC_NORMAL = $(CCC)
CCC_STRICT = $(CCC) -ansi -pedantic -Wtraditional \
-Wmissing-prototypes -Woverloaded-virtual \
-Wwrite-strings -Wconversion -Wstrict-prototypes\
-Wpointer-arith -Winline
G++_NORMAL = $(G++)
G++_STRICT = $(G++) -ansi -pedantic -Wtraditional
CXX = $($(CPLUSPLUS)_$(CXXCMPLR))
AR_CXX = $(AR_$(CPLUSPLUS))
CPP_CXX = $(CPP_$(CPLUSPLUS))
RANLIB_CXX = $(RANLIB_$(CPLUSPLUS))
LD_CXX = $(LD_$(CPLUSPLUS))
ARCH_DEP_CXXFLAGS += $($(CPLUSPLUS)_ARCH_DEP_CCFLAGS) $(ARCH_DEP_CFLAGS)
ARCH_DEP_CXXLDFLAGS = $($(CPLUSPLUS)_ARCH_DEP_LDFLAGS) $(ARCH_DEP_LDFLAGS)
# special c library requirements
SPECIAL_LANG =
# Compiler flags, don't mess with this
# Optimization flags
VX_OPT_YES = -O
VX_OPT_NO =
VX_OPT_FLAGS = $(VX_OPT_$(VX_OPT))
# Include files
VX_INCLUDES = -I. -I.. $(USR_INCLUDES) -I$(INSTALL_INCLUDE) -I$(EPICS_BASE_INCLUDE) \
-I$(EPICS_BASE_INCLUDE)/os/vxWorks -I$(VX_INCLUDE)
# Warnings
#At some time we should turn on pedantic
VX_WARN_YES = -Wall -pedantic -ansi
#VX_WARN_YES = -Wall
VX_WARN_NO =
VX_WARN_FLAGS = $(VX_WARN_$(VX_WARN))
# Operating system flags
VX_OP_SYS_FLAGS = -DvxWorks -DV5_vxWorks
# Arch dependent flags are set in CONFIG_ARCH.*
VX_CFLAGS = $(VX_OPT_FLAGS) $(VX_WARN_FLAGS) \
$(VX_INCLUDES) $(VX_OP_SYS_FLAGS)
VX_CXXFLAGS += $(VX_CFLAGS)
TARGET_CFLAGS = $($(basename $@)_CFLAGS)
TARGET_CXXFLAGS = $($(basename $@)_CXXFLAGS)
TARGET_LDFLAGS = $($(basename $@)_LDFLAGS)
TARGET_CPPFLAGS = $($(basename $@)_CPPFLAGS)
TARGET_SNCFLAGS = $($(basename $@)_SNCFLAGS)
CFLAGS = $(TARGET_CFLAGS) $(USR_CFLAGS) $(ARCH_DEP_CFLAGS) $(VX_CFLAGS)
CXXFLAGS = $(TARGET_CXXFLAGS) $(USR_CXXFLAGS) $(ARCH_DEP_CXXFLAGS) $(VX_CXXFLAGS)
LDFLAGS = $(TARGET_LDFLAGS) $(USR_LDFLAGS) $(ARCH_DEP_LDFLAGS) $(VX_LDFLAGS)
LDLIBS = $(TARGET_LDLIBS) $(USR_LDLIBS) $(ARCH_DEP_LDLIBS) $(VX_LDLIBS)
CXXLDLIBS = $(TARGET_LDLIBS) $(USR_CXXLDLIBS) $(ARCH_DEP_LDLIBS) $(VX_LDLIBS)
CXXLDFLAGS = $(TARGET_LDFLAGS) $(USR_CXXLDFLAGS) $(ARCH_DEP_CXXLDFLAGS) $(VX_LDFLAGS)
CPPFLAGS += $(TARGET_CPPFLAGS) $(USR_CPPFLAGS)
# Build compile line here
COMPILE.c = $(CC) $(CFLAGS) $(CPPFLAGS) -c
LINK.c = $(LD) $(LDFLAGS) -o
COMPILE.cc = $(CXX) $(CXXFLAGS) $(CPPFLAGS) -c
LINK.cc = $(LD_CXX) $(CXXLDFLAGS) -o
CPPSNCFLAGS = $(VX_INCLUDES)
DEPENDS_RULE.c = -$(COMPILE.c) -M $(SRCS.c) >> .DEPENDS
DEPENDS_RULE.cc = -$(COMPILE.cc) -M $(SRCS.cc) >> .DEPENDS
# Allow site host architecture specific overrides
-include $(EPICS_BASE)/config/CONFIG_SITE.$(BUILD_TYPE).$(ARCH_CLASS).$(HOST_ARCH)
3) /base/config/CONFIG.mv162
# $Id: CONFIG.mv162,v 1.1 1996/07/11 19:16:25 jba Exp $
# BUILD_TYPE
BUILD_TYPE = Vx
# For Vx directories of form:
# $(VX_DIR)/$(HOST_ARCH).$(ARCH_CLASS)/bin
ARCH_CLASS = 68k
include $(EPICS_BASE)/config/CONFIG.$(BUILD_TYPE).$(ARCH_CLASS)
# Architecture specific build flags
ARCH_DEP_CFLAGS = -DCPU=MC68040 -m68040 -DCPU_FAMILY=MC680X0
4) /base/config/CONFIG.solaris
# $Id: CONFIG.solaris,v 1.14 1997/04/23 16:55:23 jhill Exp $
# BUILD_TYPE
# Currently either Vx or Host
BUILD_TYPE = Host
ARCH_CLASS = solaris
# Compiler and utility invocation (supply path to compiler here)
# (with warning flags built in)
# Paths to compilers
GCC = /usr/local/bin/gcc
ACC = $(SPARCWORKS)/bin/cc
# SUNCC doesn't exist under Solaris
# required by sun's C++ compiler
AR = ar
_AR = $(AR) $(ARFLAGS)
G++_AR = $(_AR)
CCC_AR = $(CCC) -xar -o
ARCMD = $($(CPLUSPLUS)_AR)
RANLIB =
YACC = $(EYACC)
LEX = $(ELEX)
G++ = /usr/local/bin/g++
CCC = /opt/SUNWspro/bin/CC
CP=cp
MV=mv
RM=rm -f
MKDIR=mkdir
RMDIR=rm -rf
CHMOD = "/bin/chmod"
WHAT = what
EXE=
OBJ=.o
ACC_ANSI_INVOKE_W_NO = $(ACC) -Xa -w
ACC_ANSI_INVOKE_W_YES = $(ACC) -Xa
ACC_STRICT_INVOKE_W_YES = $(ACC) -Xc -v
ACC_TRAD_INVOKE_W_NO = $(ACC) -Xs -w
ACC_TRAD_INVOKE_W_YES = $(ACC) -Xs
ACC_LD_FLAGS =
ACC_LD_LIBS =
SUNCC_TRAD_INVOKE_W_NO = $(ACC_TRAD_INVOKE_W_NO)
SUNCC_TRAD_INVOKE_W_YES = $(ACC_TRAD_INVOKE_W_YES)
GCC_ANSI_INVOKE_W_NO = $(GCC) -ansi -w
GCC_ANSI_INVOKE_W_YES = $(GCC) -ansi
GCC_STRICT_INVOKE_W_YES = $(GCC) -ansi -Wall -pedantic
GCC_TRAD_INVOKE_W_NO = $(GCC) -traditional -w
GCC_TRAD_INVOKE_W_YES = $(GCC) -traditional
GCC_LD_LIBS =
GCC_LD_FLAGS =
C_OLD = $($(STANDARD)_TRAD_INVOKE_W_$(UNIX_WARN))
C_ANSI = $($(ANSI)_ANSI_INVOKE_W_$(UNIX_WARN))
C_STRICT = $($(ANSI)_STRICT_INVOKE_W_YES)
CC = $(C_$(CMPLR))
LD_LIBS_OLD = $($(STANDARD)_LD_LIBS)
LD_LIBS_ANSI = $($(ANSI)_LD_LIBS)
LD_LIBS_STRICT = $($(ANSI)_LD_LIBS)
CCOMPILER_LDLIBS = $(LD_LIBS_$(CMPLR))
LD_FLAGS_OLD = $($(STANDARD)_LD_FLAGS)
LD_FLAGS_ANSI = $($(ANSI)_LD_FLAGS)
LD_FLAGS_STRICT = $($(ANSI)_LD_FLAGS)
CCOMPILER_LDFLAGS = $(LD_FLAGS_$(CMPLR))
CCC_NORMAL_INVOKE_W_NO = $(CCC) +p
CCC_NORMAL_INVOKE_W_YES = $(CCC) +p +w
CCC_STRICT_INVOKE_W_YES = $(CCC) +p +w
CCC_LD_FLAGS = -L$(SPECIAL_LANG)
CCC_LD_LIBS =
CCC_TEMPL_INST_FLAG =
G++_NORMAL_INVOKE_W_NO = $(G++) -ansi -pedantic -w
G++_NORMAL_INVOKE_W_YES = $(G++) -ansi -pedantic -Wall
G++_STRICT_INVOKE_W_YES = $(G++) -ansi -pedantic -Wtraditional -Wall \
G++_TEMPL_INST_FLAG = -DEXPL_TEMPL
CXX_NORMAL = $($(CPLUSPLUS)_NORMAL_INVOKE_W_$(UNIX_WARN))
CXX_STRICT = $($(CPLUSPLUS)_STRICT_INVOKE_W_YES)
TEMPL_INST_CXXFLAG = $($(CPLUSPLUS)_TEMPL_INST_FLAG)
# GNU make likes CXX instead of CCC
CXX = $(CXX_$(CXXCMPLR))
# Static Build options
#ACC_SFLAGS_YES= -dn
ACC_SFLAGS_YES= -Bstatic
ACC_SLIBS_YES= -lw -lintl -Bdynamic -ldl -Bstatic -lXext -lX
ACC_SLIBS_NO=
ACC_SFLAGS_NO=
CC_SFLAGS_YES= -dn
CC_SFLAGS_NO=
GCC_SFLAGS_YES= -static
GCC_SFLAGS_NO=
SF_OLD = $($(STANDARD)_SFLAGS_$(STATIC_BUILD))
SF_ANSI = $($(ANSI)_SFLAGS_$(STATIC_BUILD))
SF_STRICT = $(SF_ANSI)
UNIX_SFLAGS = $(SF_$(CMPLR))
SL_OLD = $($(STANDARD)_SLIBS_$(STATIC_BUILD))
SL_ANSI = $($(ANSI)_SLIBS_$(STATIC_BUILD))
SL_STRICT = $(SL_ANSI)
UNIX_SLIBS = $(SL_$(CMPLR))
# Optimization
OPTIM_YES = -O
OPTIM_NO =
UNIX_OPT_FLAGS = $(OPTIM_$(UNIX_OPT))
# Include files
UNIX_INCLUDES = -I. -I.. $(USR_INCLUDES) -I$(INSTALL_INCLUDE) -I$(EPICS_BASE_INCLUDE) \
-I$(EPICS_BASE_INCLUDE)/os/$(T_A)
OP_SYS_FLAGS = -DUNIX
UNIX_LDFLAGS = -L$(EPICS_BASE_LIB) $(CCOMPILER_LDFLAGS)
UNIX_LDLIBS = $(UNIX_SLIBS) -lm $(CCOMPILER_LDLIBS)
ARCH_DEP_CFLAGS = -DSOLARIS
ARCH_DEP_CXXFLAGS = $(ARCH_DEP_CFLAGS)
ARCH_DEP_LDLIBS = -lsocket -lnsl
# -lsocket needed by libca.a
# -lnsl needed by libca.a
UNIX_CFLAGS = $(UNIX_SFLAGS) $(UNIX_INCLUDES) $(OP_SYS_FLAGS)
UNIX_CXXFLAGS = $(UNIX_CFLAGS)
# Target specific flags
TARGET_LDLIBS = $($(basename $@)_LDLIBS)
CFLAGS = $(UNIX_OPT_FLAGS) $(TARGET_CFLAGS) $(USR_CFLAGS) $(ARCH_DEP_CFLAGS) $(UNIX_CFLAGS)
CXXFLAGS = $(UNIX_OPT_FLAGS) $(TARGET_CXXFLAGS) $(USR_CXXFLAGS) \
$(ARCH_DEP_CXXFLAGS) $(UNIX_CXXFLAGS) $(TEMPL_INST_CXXFLAG)
LDFLAGS = $(SPECIAL_LDFLAGS) $(TARGET_LDFLAGS) $(USR_LDFLAGS) $(ARCH_DEP_LDFLAGS) $(UNIX_LDFLAGS)
LDLIBS = $(TARGET_LDLIBS) $(USR_LDLIBS) $(ARCH_DEP_LDLIBS) $(UNIX_LDLIBS)
# Override SUN defaults
# Unlike the 'Unix' makesystem, output flags -o .. are now part of LINK.c[c]
LINK.c = $(CC) -o $@ $(CFLAGS) $(CPPFLAGS) $(LDFLAGS)
LINK.cc = $(CXX) -o $@ $(CXXFLAGS) $(CPPFLAGS) $(LDFLAGS)
DEPENDS_RULE.c = -$(COMPILE.c) -xM $(SRCS.c) > .DEPENDS
DEPENDS_RULE.cc = -$(COMPILE.cc) -xM $(SRCS.cc) >> .DEPENDS
5) /base/config/CONFIG_BASE
# $Id: CONFIG_BASE,v 1.14 1997/06/25 06:40:24 jhill Exp $
# the order of following list is important
# for c++ build add the dirs gdd and cas after ca
# (and uncomment the c++ files in src/lbCom/Makefile.Unix)
DIRS = tools
DIRS += include
DIRS += cxxTemplates
DIRS += toolsComm
DIRS += libCom
DIRS += libvxWorks
DIRS += cvtDctsdr
DIRS += dbStatic
DIRS += db
DIRS += bpt
DIRS += ca
DIRS += util
DIRS += misc
DIRS += sequencer
DIRS += dbtools
DIRS += rsrv
DIRS += rec
DIRS += as
DIRS += drv
DIRS += dev
DIRS += devOpt
DIRS += iocCore
# if CPLUSPLUS isnt empty then include C++ src codes
DIRS += $(patsubst %,gdd,$(strip $(CPLUSPLUS)))
DIRS += $(patsubst %,cas,$(strip $(CPLUSPLUS)))
EPICS_BASE = $(TOP)
# EPICS include config file
EPICS_BASE = $(INSTALL_LOCATION)
# this speeds up the build by turning off implicit rules search
# for EPICS Makefiles (which are not created from other files)
.PHONY:: $(TOP)/config/CONFIG
.PHONY:: $(TOP)/config/CONFIG.* $(TOP)/config/CONFIG_*
.PHONY:: $(TOP)/config/RULES.* $(TOP)/config/RULES_* .DEPENDS
.PHONY:: $(HOME)/EPICS_CONFIG $(HOME)/EPICS_CONFIG.$(HOST_ARCH)
.PHONY:: ../Makefile.Vx ../Makefile.Unix ../Makefile.Host Makefile
6) /base/config/CONFIG_COMMON
# $Id: CONFIG_COMMON,v 1.9 1997/06/25 06:37:23 jhill Exp $
# CONFIG_COMMON - Another EPICS BASE config file
# by Matthew Needes and Mike Bordua
# This file is to be maintained by the EPICS community.
# Common Configuration Information
# CROSS1 will be defined only when CROSS_COMPILER_HOST_ARCHS is NOT defined
CROSS1 = $(CROSS_COMPILER_TARGET_ARCHS$(word 1,$(CROSS_COMPILER_HOST_ARCHS)))
# CROSS2 will be defined only when CROSS_COMPILER_HOST_ARCHS is defined
# and HOST_ARCH is one of it's words
CROSS2 = $(CROSS_COMPILER_TARGET_ARCHS$(filter-out 1,$(words $(filter $(HOST_ARCH),$(CROSS_COMPILER_HOST_ARCHS)))))
BUILD_ARCHS = $(HOST_ARCH) $(CROSS1) $(CROSS2)
INSTALL_LOCATION = $(TOP)
INSTALL_LOCATION_LIB = $(INSTALL_LOCATION)/lib
INSTALL_LOCATION_BIN = $(INSTALL_LOCATION)/bin
INSTALL_INCLUDE = $(INSTALL_LOCATION)/include
INSTALL_DOC = $(INSTALL_LOCATION)/doc
INSTALL_MAN = $(INSTALL_LOCATION)/man
INSTALL_TEMPLATES = $(INSTALL_LOCATION)/templates
INSTALL_DBD = $(INSTALL_LOCATION)/dbd
INSTALL_CONFIG = $(INSTALL_LOCATION)/config
EPICS_BASE_INCLUDE = $(EPICS_BASE)/include
EPICS_BASE_DBD = $(EPICS_BASE)/dbd
EPICS_EXTENSIONS_INCLUDE = $(EPICS_EXTENSIONS)/include
EPICS_EXTENSIONS_TEMPLATES = $(EPICS_EXTENSIONS)/templates
DIVIDER = .
EPICS_BASE_HOST_BIN = $(EPICS_BASE)/bin/$(HOST_ARCH)
# private versions of lex/yacc from EPICS
EYACC = $(EPICS_BASE_HOST_BIN)/antelope$(EXE)
ELEX = $(EPICS_BASE_HOST_BIN)/e_flex$(EXE) -S$(EPICS_BASE_INCLUDE)/flex.skel.static
# Default for perl if it's on the PATH,
# otherwise override this in e.g. CONFIG_SITE
PERL=perl
# install from EPICS
INSTALL = $(PERL) $(EPICS_BASE_HOST_BIN)/installEpics.pl
INSTALL_PRODUCT = $(INSTALL)
# dbtools from EPICS
# state notation language compiler (installed from base/src/sequencer)
SNC = $(EPICS_BASE_HOST_BIN)/snc
# vxWorks definitions
VX_CONFIG_DIR = $(VX_DIR)/config
VX_INCLUDE = $(VX_DIR)/h
#VX_GNU_BIN = $(VX_GNU)/$(HOST_ARCH).$(ARCH_CLASS)/bin
VX_GNU_BIN = /usr/local/tornado-1.0.1/host/sun4-solaris2/bin
#VX_GNU_LIB = $(VX_GNU)/$(HOST_ARCH).$(ARCH_CLASS)/lib
VX_GNU_LIB = /usr/local/tornado-1.0.1/host/sun4-solaris2/lib
ifdef T_A
INSTALL_LIB = $(INSTALL_LOCATION_LIB)/$(T_A)
INSTALL_TCLLIB = $(INSTALL_LOCATION_LIB)/$(T_A)
INSTALL_BIN = $(INSTALL_LOCATION_BIN)/$(T_A)
EPICS_BASE_LIB = $(EPICS_BASE)/lib/$(T_A)
EPICS_BASE_BIN = $(EPICS_BASE)/bin/$(T_A)
EPICS_EXTENSIONS_LIB = $(EPICS_EXTENSIONS)/lib/$(T_A)
EPICS_EXTENSIONS_BIN = $(EPICS_EXTENSIONS)/bin/$(T_A)
VX_IMAGE = $(VX_CONFIG_DIR)/$(T_A)/vxWorks
VX_IMAGE_SYM = $(VX_CONFIG_DIR)/$(T_A)/vxWorks.sym
# location of installed vxWorks image
EPICS_VX_IMAGE = $(EPICS_BASE_BIN)/vxWorks
EPICS_VX_IMAGE_SYM = $(EPICS_BASE_BIN)/vxWorks.sym
endif
7) base/config/CONFIG_SITE
# $Id: CONFIG_SITE,v 1.12 1997/06/25 14:09:40 jba Exp $
# CONFIG_SITE - EPICS BASE config file
# This file is to be modified by the EPICS system manager
# only.
# The host architecture performing the build,
# i.e.: the arch running DCT/getrel/etc.
# Currently Supporting:
# sun4
# hp700
# alpha
# solaris
# sgi
# Linux
# WIN32
# HOST_ARCH now an environment variable
HOST_ARCH=$(shell /usr/local/epics/startup/HostArch)
ifndef HOST_ARCH
HOST_ARCH=unsupported
endif
# The architectures to build EPICS for
# mv167
# mv162
# mv162lc
# mv147
# hkv2f
# niCpu030
# pc486
#CROSS_COMPILER_TARGET_ARCHS=mv167
CROSS_COMPILER_TARGET_ARCHS=mv162
# If only a subset of the host architectures perform
# the build for the CROSS_COMPILER_TARGET_ARCHS
# uncomment the following line and specify them.
CROSS_COMPILER_HOST_ARCHS=solaris
# VxWorks directory
#VX_DIR=$(VW)
VX_DIR=/usr/local/tornado-1.0.1/target
# Gnu directory for gcc
#VX_GNU = $(VX_GNU)
VX_GNU = /usr/local/tornado-1.0.1/host/sun4-solaris2
# Gnu directory for g++
#GNU_DIR = $(LOCAL_GNU)
GNU_DIR = /usr/local/hideos/gnu
GNU_BIN = $(GNU_DIR)/bin
GNU_LIB = $(GNU_DIR)/lib
# Client ANSI Compiler
# GCC (gcc -ansi)
# ACC (acc)
# HPACC (cc -Aa)
#ANSI=HPACC
ANSI=ACC
# Client Standard C Compiler choice
# GCC (gcc -traditional)
# ACC (acc -Xs)
# SUNCC (cc)
# HPCC (cc -Ac)
#STANDARD=HPCC
STANDARD=ACC
# C++ Compiler
# G++ (g++) GNU C++
# CCC (CC) OS VENDOR C++
#CPLUSPLUS=G++
#Note: if CPLUSPLUS is empty then C++ src codes are not built
#CPLUSPLUS= # use this if site does not have C++ compiler
CPLUSPLUS=CCC
# must be either YES or NO
STATIC_BUILD=NO
# Unix Optimization
UNIX_OPT=YES
VX_OPT=YES
UNIX_WARN=YES
VX_WARN=YES
# adl2dl
ADL2DL = $(EPICS_EXTENSIONS)/bin/$(HOST_ARCH)/adl2dl
# sch2edif compiler and flags
SCH2EDIF = sch2edif
SCH2EDIF_PATH =
SCH2EDIF_SYSFLAGS = -n -ap -p.+..+$(SCH2EDIF_PATH)+$(EPICS_EXTENSIONS)/templates/capfast/sym+
SCH2EDIF_FLAGS =
# e2db and flags
# - again there is an assumption where edb.def is installed.
E2DB = $(EPICS_EXTENSIONS)/bin/$(HOST_ARCH)/e2db
E2DB_SYSFLAGS = -ate -d $(EPICS_EXTENSIONS)/templates/capfast/edb.def
E2DB_FLAGS =
8) /base/config/CONFIG_SITE.solaris
# $Id: CONFIG_SITE.solaris,v 1.3 1996/08/14 20:46:24 jba Exp $
# Site Specific Configuration Information
# Only the local epics system manager should modify this file
# Default SUN compiler, individual Makefiles will override
# if they cannot support ANSI compilation.
# STRICT - ANSI C - force warning flags
# ANSI - ANSI C
# OLD - Standard C - Not appropriate here.
CMPLR=ANSI
# Default SUN C++ compiler, individual Makefiles will override
# if they are coded to a higher standard.
# STRICT - ANSI C++ force strict warning flags
# NORMAL - ANSI C++ optional warning flags
CXXCMPLR=NORMAL
#CXXCMPLR=STRICT
# Unbundled C compiler stuff
SPARCWORKS = /opt/SUNWspro
#SPECIAL_LANG = $(SPARCWORKS)/lib
SPECIAL_LANG = .
Question[4] Are settings of above files right ?
Question[5] Where is the site(=URL) which I can obtain the information
about installin of EPICS-3.13.0.b11 ?
Question[6] In Compiling EPICS for mv162, must I make mv162 turn on ?
i.e) Solaris2.6 machine must communicate with mv162 target
through Tornado-1.0.1 in compiling EPICS for mv162 ?
Question[7] I want to know how I can built mv166 target.
Would you tell me the way ?
Question[8] I want to know the right compiling processes in making mv162 and
mv166. Would you tell me the way ?
Question[9] I can't obtain documentations about compiling of EPICS-3.13.0.b11
Every documentaions about EPICS installation are about old version EPICS -3.12. Where can I obtain the new version install documentations ?
Thank you for your help
I hope to receive your answer soon r answer soon.
from Yujong Kim
[email protected]
TEL/+82-562-279-1982
FAX/+82-562-279-1699
>From - Fri Mar 20 11:43:34 1998
X-Mozilla-Status: 0001
Message-ID: <[email protected]>
Date: Fri, 20 Mar 1998 11:43:27 +0900
From: System Administrator of Codia <[email protected]>
Organization: POSTECH
X-Mailer: Mozilla 3.04Gold (X11; I; SunOS 5.6 sun4u)
MIME-Version: 1.0
To: [email protected]
Subject: (no subject)
Content-Type: text/plain; charset=euc-kr
Content-Transfer-Encoding: 7bit
PAL Computational Server Codia System Administrator
Yujong Kim [email protected]
TEL/ +82-562-279-1982 FAX/ +82-562-279-1699
- Re: 3.13 Install question Ralph Lange
BUG in Record Reference Manual R3.13 Ralph Lange
<1998>
2025
2026
Re: BUG in Record Reference Manual R3.13 Bob Dalesio
<1998>
2025
2026
