1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA Server
To: "'john sinclair'" <[email protected]>, tech talk <[email protected]>
Date: Tue, 31 Mar 1998 08:40:31 -0600
I was looking at this 6 mos. or so ago and questioned Jeff Hill on a
trip down to Los Alamos.  It seems to me that we got it to work if we
could force the connection through the localhost port (by setting some
environment variable) but not over a normal port that could go to
another node.  Neither of us had any time to look into this at the time.
Jeff, do you remember our discussions?
Please let me know if you have any success.
John Hammonds
Intense Pulsed Neutron Source.
> -----Original Message-----
> From:	john sinclair [SMTP:[email protected]]
> Sent:	Monday, March 30, 1998 3:27 PM
> To:	tech talk
> Subject:	CA Server
> I have built epics base under redhat linux 5 and am trying to
> run an example CA Server, excas, as follows:
> caRepeater &
> excas &
> At this point netstat shows a process listening on udp socket 5064.
> I then run the utility ca_test as follows:
> ca_test fred
> From another window, tcpdump sees the broadcast messages
> from ca_test, but excas never seems to respond.
> Any suggestions?
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 423-576-6362
> 423-574-1268 (fax)
Prev: Re: Stops in the motor record Hubert Yamada
Next: Survey of automation techniques Peregrine M. McGehee
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA Server john sinclair
Next: Re: CA Server john sinclair
