1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Server
To: tech talk <[email protected]>
Date: Tue, 31 Mar 1998 14:05:25 -0500 (EST)
I have found a solution:
There is an environment variable named EPICS_CAS_INTF_ADDR_LIST
that may be set to the node address from which CA Server is
running. It is nice having the source code!
> I have built epics base under redhat linux 5 and am trying to
> run an example CA Server, excas, as follows:
> caRepeater &
> excas &
> At this point netstat shows a process listening on udp socket 5064.
> I then run the utility ca_test as follows:
> ca_test fred
> >From another window, tcpdump sees the broadcast messages
> from ca_test, but excas never seems to respond.
> Any suggestions?
John Sinclair
[email protected]
Oak Ridge National Lab
423-576-6362
423-574-1268 (fax)
Prev: Survey of automation techniques Peregrine M. McGehee
Next: Re: CA Server Mark S. Engbretson
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CA Server Hammonds, John
