As a follow-up to the discussion last week, included is the
text file with combining all additional details I got from
Janet Anderson over the last several years.
(Also at: http://csg.lbl.gov/EPICS/alh-new.txt)
Alarm Handler: supplementary documentation
o A new ALIAS feature which allows a user to define an alternate name for
an alarm group or channel has been implemented and can be defined in
the alarm configuration file.
Input Format:
$ALIAS <any valid text>
Description:
The line starting with $ALIAS is optional. It is required only
when a user wants to define an alternate name for an alarm
group or channel.
o A new feature which allows a user to define a unix process to be
started when the alarm severity for an alarm group or channel changes
value has been implemented and can be defined in the alarm
configuration file.
Input Format:
$SEVRCOMMAND sevrChangeValue <any valid Unix command syntax>
Description:
The line starting with $SEVRCOMMAND is optional. It is
required only when a user wants to start a Unix process when
the alarm severity value for a group or channel changes. A
single group or channel may have multiple $SEVRCOMMAND lines.
This line defines the change in the severity necessary to
start the process and defines the process to be started. Valid
severity change values are -
UP_INVALID UP_MAJOR UP_MINOR UP_ANY
DOWN_MAJOR DOWN_MINOR DOWN_NO_ALARM DOWN_ANY
started when the alarm status for an alarm channel becomes a specified
configuration file.
Input Format:
$STATCOMMAND alarmStatusStringValue <any valid Unix command
syntax>
Description:
The line starting with $STATCOMMAND is optional. It is
the alarm status becomes a specified value for a group or
channel changes. A single group or channel may have multiple
$STATCOMMAND lines. This line defines the status value
necessary to start the process and defines the process to be
started. Valid alarmStatusString values are defined in the
alarmString.h header file. Example alarm status string values are -
NO_ALARM READ WRITE HIHI HIGH READ_ACCESS
LOLO LOW STATE COS COMM WRITE_ACCESS
TIMEOUT HWLIMIT CALC SCAN LINK
SOFT BAD_SUB UDF DISABLE SIMM
o A new feature which allows alarm count filtering has been implemented
for any alarm channel and can be defined in the alarm configuration
file.
Input Format:
$ALARMCOUNTFILTER <inputCount> <seconds>
Description:
The line starting with $ALARMCOUNTFILTER is optional. It is
required only when a user wants the alarm handler to filter
the registration of alarms for a group or channel. This line
defines alarm count and seconds required for alarm
registration. To register as an alarm, an alarm channel must
remain in alarm state for more than <inputSeconds> seconds OR
the alarm channel must enter into an alarm state from a
no-alarm state more than <inputCount> times within
<inputSeconds> seconds.
Re: PLC with can interface Ralph Lange
CNAF control commands using a CES "CBD 8210 branch driver" Torben Lauritsen
<1998>
2025
2026
<1998>
2025
2026
