1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CNAF control commands using a CES "CBD 8210 branch driver"
To: [email protected]
Date: Tue, 5 May 1998 14:55:27 -0500
I have a problem issuing CNAF control commands using a CES "CBD 8210
branch driver" from a VxWorks program. Can anyone help?
I'm running VxWorks on a Nat'l Instruments VXIcpu-030 sitting in
a VXI crate with the "CBD 8210 branch driver" (seeing the backplane
through a 73A-851 Adaptor Module from Colorado Data systems/Tektronix).
Here is the story:
I can successfully use CNAF read and write commands by:
1) calculating an address as
  address = (uint32 *)
     (CAMBAS +
     ((uint16) b << CAMB) +
     ((uint16) c << CAMC) +
     ((uint16) n << CAMN) +
     ((uint16) a << CAMA) +
     ((uint16) f << CAMF) + BOARDADR + 2);
2)
and then read a value as
      data_in = *(uint16 *) address;
or write a value as
      *(uint16 *)address = data_out;
That works fine!!!
The problem comes when I try to issue CNAF control commands, I.e.,
commands with function values: 8-15 and 24-31. The manual is rather
cryptic about the command functions; but what I read is that a command
function is like a read followed by the tst instruction.
Thus, I have tried the following things
a) data_in = *(uint16 *) address;
   followed by a
   asm("tstw %0": :"a"(*(uint16 *)address));
and
b) putting the read into an if statement, expecting that
   a tst instruction will then be be generated:
   if ( data_in = *(uint16 *) address ) {};
   also tried
   if ( *(uint16 *) address ) {};
None of them worked either!
suggestions?
_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/
_/ Torben Lauritsen, Staff Scientist                            _/
_/ E-mail:     [email protected]                                   _/
_/ Snail mail: Argonne National Laboratory, Building 203,       _/
_/             9700 S. Cass Avenue, Argonne, IL 60439, USA.     _/
_/ Phone:      Office(+voice)/sec/fax: (630)252-4026/3663/6210  _/
_/ beeper-mail [email protected], reg page: 4-4026              _/
_/ URL:        http://www.phy.anl.gov                           _/
Re: CNAF control commands using a CES "CBD 8210 branch driver" Graham Waters
Prev: Recent features in ALH Steve Lewis
Next: Re: CNAF control commands using a CES "CBD 8210 branch driver" Graham Waters
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
