1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM on Linux
To: [email protected]
Cc: [email protected]
Date: Fri, 08 May 1998 11:46:29 EDT
Garrett Rinehart wrote:
> I've been running medm 2.2.9 from a Linux 4.1 pc for some months
> now. It works well for nearly a day and then dies. After much trial
> and tribulation, I have found no reason. My guess at this moment is
> that there is a "memory leak" in medm. I think that because: 1)It
> seems to run for different amounts of time with different amounts of
> memory installed. 2) It sometimes reports "out of memory for medm"
> in /var/log/messages. 3) Linux and X continue to run. In fact, to
> get around this problem, I have a cron task that checks up on medm
> and restarts it when it dies... and it works.
> Has anyone else experienced this or can anyone offer a suggestion?
I am running a hybrid medm (2.3.3 and 2.3.4beta1) on Linux 5.0 and
Motif 2.1.  I have not noticed a problem of that type, but then, I
have not left medm up for long periods of time.  I just started a
session, with a relatively large display (lots of connections).  I
will leave it up over the weekend, and check if it behaves in the same
way.  As Thomas Birke suggested, the solution _may_ be to get a newer
medm, since the problem might have been fixed in later versions.
I will let you know my results on Monday.
Mole problems?  Call Avogadro at 602-2137.
Bonnie Madre
Accelerator Development
Integration and Assessment Group
ANALOG ADDRESS:
Thomas Jefferson National Accelerator Facility (TJNAF)
MS 58
12000 Jefferson Avenue
Newport News, VA  23606
(757) 269-7059
E-MAIL ADDRESS:
[email protected]
Re: MEDM on Linux Bonnie Madre
MEDM on Linux Garrett D. Rinehart
Prev: MVME162 slow symbol table load Mark Rivers
Next: Re: MEDM on Linux Bonnie Madre
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MEDM on Linux Thomas Birke
