1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM on Linux
To: [email protected] (Garrett D. Rinehart), [email protected]
Date: Fri, 8 May 1998 16:35:52 +0200 (METDST)
>>>>> "Garrett" == Garrett D Rinehart <[email protected]> writes:
 Garrett> I've been running medm 2.2.9 from a Linux 4.1 pc for some months
 Garrett> now. It works well for nearly a day and then dies. After much
 Garrett> trial and tribulation, I have found no reason. My guess at this
 Garrett> moment is that there is a "memory leak" in medm. I think that
 Garrett> because: 1)It seems to run for different amounts of time with
 Garrett> different amounts of memory installed. 2) It sometimes reports
 Garrett> "out of memory for medm" in /var/log/messages. 3) Linux and X
 Garrett> continue to run. In fact, to get around this problem, I have a
 Garrett> cron task that checks up on medm and restarts it when it
 Garrett> dies... and it works.
 Garrett> Has anyone else experienced this or can anyone offer a
 Garrett> suggestion?
There have been memory leaks in older medm-versions (and 2.2.9 is an older
one). Although I didn't test 2.2.9 it might me a good idea to get a newer
version of medm. Both current versions (2.3.3 and 2.4.9) might have fixed
this memory-leak already.
Thomas
_______________________________________________________________________________
 /homas Birke  BESSY II   (+49)-30-6392-4934 (fax -4859)    [email protected]
MEDM on Linux Garrett D. Rinehart
Prev: Re: Problem booting ioc w/ rsh instead of ftp Ralph Lange
Next: MVME162 slow symbol table load Mark Rivers
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MEDM on Linux Garrett D. Rinehart
Next: Re: MEDM on Linux Bonnie Madre
